Old 11-16-2016, 12:57 PM
jelly jelly is offline
Proximity Manager - How to implement delay
I have a timing issue in my script, as I am not sure how to implement a delay, in that when the proximity sensor is entered, a variable (handstate) changes only after 2 seconds have elapsed.
That variable change triggers a certain action in a different function, but to keep it simple, I have copied below the proximity function I have:
def EnterProximity_IndexFinger(e): # decide what happens on sensor entry
	global handstate
	e.sensor == SensorIndexFinger
	handstate = 1
	print "sensor A entered"
	print condition
manager.onEnter(SensorIndexFinger,EnterProximity_IndexFinger)
So far, I tried to not change the handstate inside the proximity function but to use it to call another function that has a delay implemented. Something like this:
def Change():
        global handstate
        yield viztask.waitTime(2)
        handstate = 1
	global handstate
        yield Change()
Another thing I tried is to not use the "manager.onEnter" it but the "yield vizproximity.waitEnter". However, I must be doing something wrong as neither method works.
I reckon it must not be too tricky to achieve this - in essence I just want a 2 second delay after proximity sensor was entered before my action is triggered. But I am not sure how to achieve this. I would be very happy to receive some ideas or help!
Best,
J
Old 11-16-2016, 06:36 PM
Use the vizproximity.waitEnter command within a task function:
import viztask
def proximityTask():
	yield vizproximity.waitEnter(SensorIndexFinger)
	print 'entered sensor'
	print 'two seconds elapsed'
viztask.schedule(proximityTask())
Old 11-17-2016, 03:45 AM
Dear Jeff,
thank you for the help, this seems like the way to go! But I have some problems with it:
I noticed that adding the line
makes the event happen only once, upon entering the sensor for the first time.
My question would be how do I make it happen everytime, like it was the case when I used
I tried the following (somehow adding the function that specifies the delay to the manager):
SensorIndexFinger = vizproximity.Sensor(vizproximity.Box([0.03,0.03,0.03],center=[0,0,0]),IndexFinger)
manager.addSensor(SensorIndexFinger)
        global handstate
        handstate = 1
        print 'change hand'
	global handstate
	print "activate proximityTask"
manager.onEnter(SensorIndexFinger,proximityTask())
But I get an error "TypeError: 'generator' object is not callable."
I would be very happy to hear if you had any suggestions on how to call the action (with delay) every time the sensor was entered, as I can't seem to find a way to implement it
Old 11-17-2016, 04:29 PM
You can add a loop inside the task function:
	while True:
Old 11-18-2016, 09:48 AM
Smile
Thank you so much, Jeff, this works perfectly!
proximity, proximity sensor, timing
Proximity Sensing Using Kinect JamesCakes Vizard 6 06-24-2016 06:52 AM
Orientation selective (Viewing Vector) Proximity Sensor lmGehrke Vizard 2 03-17-2015 01:31 PM
Proximity Sensor Problem kmkm Vizard 3 03-04-2014 12:54 PM
Phase Space and Proximity Sensors snovob93 Vizard 3 06-13-2012 01:32 PM
Packager manager Chapre Vizard 1 04-29-2011 10:16 AM
