				Matrix
	I have loaded an object in the virtual environment. Now I want to know its 4x4 Homogenous Coordinate System and print the values in the Interactive window. How do I do that? Thanks in advance.  |
			Take a look at the node3D.getMatrix() command.
	The command that you showed returns the transform of the object in the specified coordinate system. But, my goal is to find the 4X4 matrix of an object after loading it into the virtual environment. Can you provide me with an simple exam of how I can achieve that?  |
	The command that you showed returns the transform of the object in the specified coordinate system.. But, my goal is to find the 4x4 matrix of the object after loading into the virtual environment and print those values. Can you provide me with a simple example of how it can be achieved? I would be grateful if you could help me out. Thanks in advance.  |
			Hi Jeff,
	I'm sorry I understood your point now. The command is exactly what I wanted. Could you provide me with an example of how can I obtain the 4x4 matrix using node3d.getmatrix().  |
| Different projection matrix per viewpoint | dcnieho | Vizard | 6 | 07-08-2016 06:06 AM |
| AR Marker Camera Matrix Transform Problem. | pwsnow | Vizard | 11 | 06-30-2014 05:48 PM |
| Render Node View Matrix | whaleeee | Vizard | 2 | 05-06-2013 10:26 AM |
| Projection Matrix (onto oblique near plane) | andrewjworz | Vizard | 1 | 07-13-2012 10:10 AM |
| Matrix Transform and Bumpmap | GiudiceLab | Vizard | 0 | 11-27-2009 01:42 PM |
