Old 08-07-2016, 08:13 PM
hsc hsc is offline
Walking Down the Stairs
Hi all,
I've been trying to create a falling from stairs scenario, but the my functions doesn't work as expected. The relevant code is below. Once the fall function is activated the main view moves forward and down repeatedly (bumping), but instead of going down the stairs, it's stuck in the original position. The "if" loop isn't working either.
Now I'm stuck with it and have no idea how to modify the code. Please help me if you see what the problems are. Thank you.
#Bumping
def bump():
	i=1
	while (i<10):
		position = viz.MainView.getPosition()
		position[1]+= -.5
		action1 = vizact.goto(position,0.1,viz.TIME)
		yield viz.MainView.addAction(action1)
		position[0]+= .5
		action2 = vizact.goto(position,0.1,viz.TIME)
		yield viz.MainView.addAction(action2)
		i+=1
#Spinning
def spin(e):
			euler = viz.MainView.get(viz.HEAD_EULER)
			euler[0] += e.dx*3
			euler[1] += -e.dy*3
			euler[0] = viz.clamp(euler[0],10.0,190.0)
			euler[1] = viz.clamp(euler[1],-60.0,60.0)
			viz.MainView.setEuler(euler,viz.HEAD_ORI)
#Fall
def fall():
	position2 = viz.MainView.getPosition()
	orientation2 = viz.MainView.getEuler()
	if 2.1< position2[1] <5.5:
		viz.MainView.collision(viz.OFF)
		viz.callback(viz.MOUSE_MOVE_EVENT,spin)
		viztask.schedule(bump())
vizact.ontimer(0,fall)
Old 08-09-2016, 05:59 AM
Take a look at the viewpoint collision and gravity commands. Does that work for you?
Old 08-09-2016, 08:15 PM
hsc hsc is offline
Hi Jeff, I set my collision and gravity as follows:
The MainView still doesn't go down the stairs instead just 'bumps" at one location only. I tried to change the gravity and turn off collision but still the same
# viz.MainView.collision(viz.ON)
viz.MainView.stepsize(0.6)
viz.MainView.gravity(20)
Old 08-12-2016, 01:40 AM
Can you post a working example that reproduces the issue?
# [code][/code]
Walking action of avatars SivaKartheek Vizard 3 01-08-2016 09:17 AM
Regarding Walking Action of Avatars SivaKartheek Vizard 2 12-10-2015 08:10 AM
Problem making avatar climb stairs SUJITH_KJ Vizard 8 01-20-2015 05:38 AM
Bouncing point of view during walking seal Vizard 2 10-21-2013 08:02 AM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 04:47 AM
