Thread Tools | Rate Thread | Display Modes |
Is that possible to create some connection between to sphere?
For example, I add two spheres into Vizard to represent the joints.
However, I want to create a line or some other things which can connect these two joints. When the position of the joints change, the line will move follow the joints. Thanks. |
You could create an on-the-fly line to connect the two spheres.
import viz,vizact,vizshape, vizmat viz.go() grid = vizshape.addGrid() sphere_0_left = vizshape.addSphere(radius=0.1) sphere_1_left = vizshape.addSphere(radius=0.1) |
If you want to draw a line, create a layer with viz.lines and use the center point of each sphere as a vertex. You can update the vertex positions as the sphere positions change.
is there a way to draw one line and keep updating the position |
Yes, once you create the line you can move it like any other object:
import viz import vizshape viz.go() viz.clearcolor(viz.SLATE) vizshape.addGrid() viz.startLayer(viz.LINES) viz.vertex(0,0,0) viz.vertex(0,1,0) line = viz.endLayer() line.setPosition([2,0,7]) line.color(viz.RED) |
In the code you gave to me, the length of the line is fixed, is that possible to get a line which will change its length according to the position of vertex? |
Yes, you can modify vertices to change the length of the line. Take a look at the changing vertices page from the on-the-fly section. Does this help answer your question?
| Create object with position relative to user head, but cannot be obstructed by others | Notch | Vizard | 2 | 03-03-2014 08:16 AM |
| Create a clipping box | pswaney | Vizard | 1 | 03-01-2013 01:19 PM |
| How to create AMTI AccuGait force plate plug-in using serial port connection? | manueleh | Plug-in development | 0 | 09-20-2012 02:22 PM |
| Dynamic Position and Radius of Sphere | hotshotiguana | Vizard | 1 | 03-23-2011 01:53 PM |
| Create Button or Text | Chrissy2009 | Vizard | 1 | 07-15-2009 06:34 PM |
