Old 04-09-2015, 02:55 PM
JB_HP_Viz JB_HP_Viz is offline
Reset to starting position when using Vizconnect
If I have a configuration like below and I would like to setup a way to remember the starting position and then be able to reset to that starting location if I move around.
So if I hit Key '1' and move around using keyboard and then I hit Key '2' and I fly around using Mouse/Keyboard. What is the code to reset to the starting position?
display = vizconnect.getDisplay()
keyTracker = vizconnect.getTracker('keyboard')
fly_mouseKeyTracker = vizconnect.getTracker('mouse_and_keyboard_flying')
vizact.onkeydown('1',display.setParent(keyTracker))
vizact.onkeydown('2',display.setParent(fly_mouseKeyTracker))
Thank you
John
Old 04-10-2015, 06:49 PM
I'll respond here with example code early next week.
Old 04-21-2015, 12:40 PM
Sounds good.
Thank you
Old 04-22-2015, 02:41 PM
Attached is an example that illustrates the use of viewpoints with
vizconnect. You can reset the vizconnect viewpoint to a specified location.
Old 04-30-2015, 02:58 PM
The example works great.
Thank you.
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
Changing parent without changing absolute global position? The SundanceKid Vizard 2 05-23-2014 03:43 PM
Getting updated position Anastaggra Vizard 1 02-01-2014 01:15 AM
Mouse event: how to detect no mouse move event, how to set mouse position? Zhi Vizard 3 04-11-2011 07:25 PM
default start position erchrastil Vizard 2 06-23-2008 09:15 AM
