Hello
I am using Tkinter, whenever I close any window the script remains running and it does not terminate. This is a huge issue for me any solutions? Regards |
Take a look at this thread for an example script that embeds the Vizard window in a Tk application.
Hello
I am not facing coding issues with Tkinter I am able to use it, the problem is that any script that uses Tkinter does not terminate when I close the script. Regards |
Yes I'm having the same problem. It seems that calling root.destroy() should terminate the tkinter mainloop. However in Vizard mine keeps running regardless. Not even sys.exit() does anything
Can you post an example script that replicates the issue for you?
| starting Vizard from a Python script | hotspur1 | Vizard | 12 | 06-12-2019 12:03 PM |
| Python script latency after exiting when using InterSense IC2+ | fordprefect | Vizard | 1 | 03-18-2014 11:58 PM |
| How are files associated/how should they be saved (python script + images) | mhead10 | Vizard | 1 | 03-26-2012 10:58 AM |
| Simplest script not working | vasiliys | Vizard | 2 | 10-25-2011 10:24 AM |
| script file available - but missing | spdegabrielle | Vizard | 1 | 05-06-2009 10:04 AM |
