Old 02-12-2008, 07:56 AM
DavidHeesom DavidHeesom is offline
TK with Vizard
Hi
Just downloaded and started to play with TK and Vizard as we want to create an application that uses a windows style interface and menus but is it possible to embed the vizard graphics window into a TK application or is there an example on the forum I have missed somewhere.
Thanks for any help...
Old 02-13-2008, 02:19 PM
Here is a simple script that embeds the Vizard graphics window in a Tk application:
from Tkinter import *
import win32gui
class VizardApp(Frame):
	def __init__(self, master=None):
		Frame.__init__(self, master,width=800, height=600)
		self.pack()
		#Embed vizard using the viz.EMBEDDED flag and passing handle to existing window
		viz.go(viz.EMBEDDED,window=self.winfo_id())
		#Initialize Vizard environment
		viz.add('tut_ground.wrl')
		ball = viz.add('ball.wrl',pos=(0,1.8,2))
		ball.add(vizact.spin(0,1,0,90))
		#Need to setup timer to manually update vizard engine
		self.after(10,self.updateVizard)
	def updateVizard(self):
		"""Update the vizard engine"""
		viz.updateframe()
# create the application
myapp = VizardApp()
# set title of application
myapp.master.title("Vizard Tkinter example")
# start the program
myapp.mainloop()
We have also embedded Vizard in wxPython applications, and it works a lot better than Tk. If you are not too attached to using Tk, then I would recommend using wxPython.
Old 02-19-2008, 08:24 AM
Thats great - thanks. I've downloaded wxPython and started looking at that at the moment. Thanks for the help.
McAfee Privacy Service 8.1 causes Vizard not to run mspusch Vizard 2 09-24-2008 05:17 PM
McAfee Privacy Service 8.1 causes Vizard not to run mspusch Vizard 0 03-01-2007 08:24 PM
