Old 02-18-2015, 04:26 AM
yudhidayak yudhidayak is offline
Cluster master/client problem
Dear all,
We have the CornerCavern VR System at our engineering centre. It seems that we have a problem with the cluster master (?) where objects on screen appear 'double' (not focus) even though we wear the Stereo glasses.
The page (http://docs.worldviz.com/vizard/Conn...ur_cluster.htm) shows that if we launch the Vizard Cluster Client, the window shows:
"**Received ping from RENDERER2 (10.24.5.145)"
but, it did not appear on our system.
I assumed (I may be wrong) the Vizard Cluster Client does not receive any signal.
Any advice and suggestions will be greatly appreciated.
(Apologies if this topic has been discussed)
Kind regards,
Yudhi
Old 02-18-2015, 05:26 AM
Are the images on both walls matching up and synced with each other? If so, then it sounds like you have the cluster setup properly. The double image maybe due to inverted stereo. On that machine you can go into the nvidia control panel under 'Manage 3D settings'. Try changing the 'Stereo - Swap Eyes' setting.
"Launching in cluster master mode." when cluster mode disabled jpriede Vizard 2 02-12-2013 02:33 PM
Question about cluster replacement mizutani_jun Vizard 1 02-18-2011 02:49 PM
Vizard problem mizutani_jun Vizard 4 01-09-2011 03:39 PM
Cluster Help videcuk Vizard 12 09-21-2007 02:14 PM
