Old 10-30-2014, 09:27 AM
andreionutz andreionutz is offline
vizact move action
I have a problem with using the move action in Vizard 4&5. the simple use case is i am navigating with the MainView through actions. I have viz.MainView.collision( viz.ON ) so that i don't go through walls, and in case of collision i cancel the current action and clear the action list. but i still move backwards (sometimes), away from the collision point. i looked a lot in the documentation and a bit in the vizact source code and i don't find a way to prevent this. on the contrary, i found a confirmation of the behavior in the VizMoveAction class.
how can i solve this? i want to keep things simple and not necessarily realistic, that's why i'm avoiding physics.
Best,
Andrei
Old 10-30-2014, 10:26 AM
no that i think of it, the problem is maybe less related to vizact and more to the model i'm using. i mentioned vizact because there i can see more clearily what's happening and it's where i spend my last hopes of solving the problem by myself. but i get the same behavior while navigating with the mouse. the model i have is a valid collada model and the normals are ok. i don't have the bounce back effect if the collision surface is aligned along the x/z axes, which i find really strange...
Old 10-31-2014, 07:41 AM
me again.
i stripped down my code to the very basic and still didn't find a solution. i can't see how anything could be wrong in the usage, but i posted the code below anyway. i also tried different models from 3D Warehouse and i could reproduce the problem.
attached is a very simple collada model i generate myself(rename to .dae). the normals are ok, but i still have the bumping effect when the wall is oblique. i think the problem is somewhere in the Vizard navigation code and has something to do with vector decomposition, otherwise i cannot explain why it's not happening when the wall is parallel with an axis...
viz.setOption('viz.model.apply_collada_scale',1)
world = viz.addChild('.\\..\\configs\maze3D.dae')
world.collideMesh()
env = viz.addEnvironmentMap('sky.jpg')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
viz.disable(viz.LIGHTING)
viz.MainView.collision(viz.ON)
viz.MainView.setPosition(3.02036, 0.00000, -0.08363)
viz.MainView.eyeheight(0.11)
Old 11-04-2014, 04:09 AM
Hi there,
i've been trying to different geometries, i've tried to use physics, nothing seems to work. can anyone tell me what am i doing wrong? is this bounce made by design? isn't there any way to avoid it?
i can split the move commands in smaller ones and manage to hide a bit the behavior, but still doesn't solve the problem.
any ideas? suggestions?
Old 11-04-2014, 06:47 PM
I ran your example code with model and notice the viewpoint bounces when colliding with the edge of a wall. Is that what you are describing or does it occur at other times as well?
Old 11-04-2014, 06:54 PM
Does changing the collision buffer affect the bounce you see?
Old 11-05-2014, 04:02 AM
hi Jeff,
a few details about the test/problem - i am getting towards the wall until collision. then i try to advance oblique against the wall. what i expect is to slide along. instead i slide and bounce at the same time. it happens on the whole length of the wall, as long as the wall is not parallel with one of the axis.
i already did try to change the collision buffer, but with no success. did it work for you? with what value?
Old 11-07-2014, 10:36 AM
since the problem is still not solved i thought to come with my latests feedback. i have an even simpler script to reproduce it:
viz.MainView.collisionBuffer(1)
world = viz.add('lab.osgb')
#commenting this line makes the bouncing effect dissapear
world.setEuler(30, 0, 0)
i think that it's a bug and it has to do with using the wrong (global) coordinates when calculating the collision. that's why it works when the the walls are parallel with the axes. but this is code i cannot see and i wouldn't be able to change it anyway.
or maybe i'm wrong...
any other ideas?
thank you,
andrei
Old 11-07-2014, 04:49 PM
Thanks for the simple example. I'll check with a developer about this.
Old 11-12-2014, 07:39 AM
thank you for support. looking forward for the solution.
don't hesitate to contact me in case you need more details.
Old 11-14-2014, 12:34 PM
Sorry, I don't have a solution to provide here. This is a limitation of viewpoint collision.
Old 11-14-2014, 12:58 PM
so what would you suggest?
Old 11-14-2014, 02:04 PM
If the walls are only slightly off parallel from the XZ axes the following may be an option. Use two models, one for the visible geometry and another that's not rendered and used for collision detection. The collision model surfaces would need to be parallel to the XZ surfaces and there would be a displacement between the visible and collision meshes.
Old 11-19-2014, 03:54 AM
i have no restrictions for the geometries, and actually very little knowledge about the model as a whole. the user can generate 3d content and use it, and therefore the walls can be anything.
collision, vizact
Using move() and spinTo efficiently Shweta Vizard 3 07-29-2014 06:10 PM
Hand Grab and Object Action rmcconnell11 Vizard 2 04-30-2014 07:51 AM
how to move seperately? nasr Vizard 2 05-11-2009 02:57 AM
move animated camera around corner question nlfrnassimi Vizard 1 02-23-2009 10:45 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
