Old 07-18-2008, 08:38 AM
fc2008 fc2008 is offline
object in information box
Heya, I have an object - draft_text
I want to be included within an information box that pops up, how would I do this?
This is so when a user types a message it appears within that box
Also, how would I get the information box to follow an avatar around the screen?
The code i am using to create a networked chat box is below
Thanks in advance, FC
sent_message.visible(0)
typing_message.visible(0)
#Use a prompt to ask the user the network name of the other computer.
target_machine = viz.input('Enter the name of the other machine').upper()
#Add a mailbox from which to send messages. This is your outbox.
target_mailbox = viz.addNetwork(target_machine)
#Start with sending_text as a blank space.
out_text = ''
def SendData():
    #Retrieve current transform of viewpoint
    mat = viz.MainView.getMatrix()
    #Apply offsets so duck model matches viewpoint
    mat.preEuler(180,0,0)
    mat.preTrans(0,-1,0)
 #Send position/rotation to target network object
    target_mailbox.send(quat=mat.getQuat(),pos=mat.getPosition(),message=out_text)
# Start a timer that sends out data over the network every frame
vizact.ontimer(0,SendData)
# Listens for any incomming messages
def onNetwork(e):
    avatar.setPosition(e.pos)
    avatar.setQuat(e.quat)
    inbox.message(e.message)
# Register network to listen from incoming messages
viz.callback(viz.NETWORK_EVENT, onNetwork)
#Create a variable for the draft of the outgoing message.
draft_text = ' '
def mykeyboard(key):
    global out_text, draft_text
    #If the length of the key is 1 then
    #add the character to the string.
    if draft_text == '':
    if len(key) == 1:
        draft_text += key
        typing_message.visible(1)
#If the key is a character return, end the line, make the
#outgoing message equal to the draft message, and set the draft equal
    # to a blank space.
    elif key == viz.KEY_RETURN:
        out_text = draft_text
        sent_message.visible(1)
    #If the key is the backspace key then remove the last character of the string.
    elif key == viz.KEY_BACKSPACE:
        draft_text = draft_text[:-1]
    #Update the input text field so that you can see what you're typing.
    outbox.message(draft_text)
    print draft_text
Old 07-22-2008, 12:25 PM
You can use the vizinfo module to display an information box. You can use the viz.MainWindow.worldToScreen command to convert world coordinates to screen coordinates, in order to position the info box near the avatar. Here is some sample code that shows how to accomplish this:
#Create avatar
female = viz.add('vcc_female.cfg',euler=(180,0,0),pos=(0,0,6))
#Create info box that is aligned to lower left corner
import vizinfo
info = vizinfo.add('')
info.alignment(vizinfo.LOWER_LEFT)
#Setup timer to position info box near avatar head
def UpdateInfoPosition():
	m = female.getBone('Bip01 Head').getMatrix(viz.AVATAR_WORLD)
	m.preTrans(0,0.2,0)
	x,y,z = viz.MainWindow.worldToScreen(m.getPosition())
	info.translate(x+0.03,y+0.02)
	info.visible(z>0)
vizact.ontimer(0,UpdateInfoPosition)
#Use the following code to change the message of the box
info.message('hello')
Old 06-11-2013, 07:35 AM
CompSci CompSci is offline
Can you please add the code that enables real-time editing to this message box??
#Create avatar
import vizinfo
	m.preTrans(0,0.2,0)
	info.visible(z>0)
Old 06-11-2013, 10:17 AM
You can change the content of a info box using the info.message command. Register a callback function for key events and in that function change the message value based on keys pressed.
Old 06-12-2013, 05:09 AM
I will give this a try, thank you.
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 11:33 AM
when collision mode is on, can i "turn it off" for an individual object? Vdoug Vizard 1 09-22-2005 12:14 PM
Moving view with object Xliben Vizard 2 07-25-2005 05:36 PM
