Old 03-12-2013, 12:02 PM
Chapre Chapre is offline
Question Audio Informaion
How do I get audio basic information like duration without having to load it (not using viz.addAudio); as loading takes quite some time that would be critical for my application
Old 03-13-2013, 01:57 AM
Perhaps there is some 3rd party Python library that will allow you to access properties of the audio file. Can you save the information to a text file and read it from there?
Old 04-12-2013, 05:40 PM
masaki masaki is offline
Mutagen is a good library for this and you won't have to save the information out; you can just extract the information from the file without loading it into memory.
https://code.google.com/p/mutagen/
Masaki
Adding Audio to CAF Animation WaterBottle Vizard 3 08-30-2011 06:54 PM
Audio does not play (even the one from the multimedia.py tutorial) Josh Vizard 2 03-10-2010 11:04 AM
Add an audio source (a radio)? Josh Vizard 4 03-05-2010 09:01 AM
Real Time Audio Data lomendil Vizard 2 06-02-2008 08:18 PM
audio object string Jerry Vizard 1 03-13-2008 11:06 AM
