Old 01-26-2013, 06:46 AM
Daithi90 Daithi90 is offline
Trouble with vizact.speak()
When I use the speak action, the avatar's mouth moves but there's no audio. It had been working for me except with the avatar's actions being a bit glitchy. I subbed in JFK.wav to see if it would glitch and it didn't but since I've gone back to the original file, the audio won't play. Is this a known bug?
Old 01-29-2013, 08:46 AM
Could you post the code that is causing the problem? I think I've had a similar problem, also experienced avatars acting a bit glitchy, but that could be due to the speak action.
Old 02-16-2013, 05:18 PM
Strangely enough it started working with some other .wav files and I've not had problems with it since. So I'm not entirely sure what the problem was.
Old 02-18-2013, 06:31 AM
fabioped fabioped is offline
Try setting sync=True as speak() argument
Trouble using custom animations for Live Characters IGoudt Vizard 0 09-24-2009 06:37 AM
trouble tracking multiple lights Vkathrynr Precision Position Tracker (PPT) 2 08-26-2009 12:07 PM
Trouble transitioning from one vizard DBurks2818 Vizard 3 04-28-2009 02:46 PM
trouble changing subnode (child node) color, alpha, etc. michaelrepucci Vizard 7 01-14-2009 08:38 PM
multiple timer trouble exhale Vizard 2 04-26-2005 12:21 AM
