Is there any open file GUI
Can I build a GUI in vizard, like below, that allow user to open and choose some files and import them into vizard?
I mean build a button, and when click the button, it can call an open file GUI in which people can browse and choose files to be open?
There's an example over in the Vizard 2.5 forum. Here's a link to it:http://forum.worldviz.com/showthread...light=win32gui
I've tried it under Vizard 3 and it works, no problem. Aaron |
Sorry for bumping this thread but when I attempt to use the code in this example I get this error:
** Load Time: 0.01 seconds
File "Vizard2.py", line 3, in ?
inFileDlg = win32ui.CreateFileDialog(1, '', 'foo.txt')
TypeError: None is not a valid string in this context
![]() I really need to be able to navigate to and open various files and this seemed the ideal way to do it except I can't get it to work!! I'd be really grateful for any ideas regarding this, Cheers |
Ok, I'm getting somewhere here I think. Here's what I am using now:
def ChooseFile(): """You can find documentation for CreateFileDialog at the following site: http://aspn.activestate.com/ASPN/docs/ActivePython/2.5/pywin32/win32ui__CreateFileDialog_meth.html""" parent = win32ui.CreateWindowFromHandle(viz.window.getHandle()) dlg = win32ui.CreateFileDialog(1,'','',0,'',parent) if dlg.DoModal() == win32con.IDOK: file = dlg.GetFileName() inFileName = dlg.GetPathName() print file print inFileName ![]() However, what I would really like to do is open the selected file, so I tried adding: Code:
FILE = open(file, 'r') for line in FILE: print line Code:
ÐÏࡱ ![]() So my question is - what am I doing wrong here, I just want a participant to be able to select a file which is then read in / parsed into useful chunks of data. Also when exiting winviz after running this I get a - "winviz.exe has encountered a problem and needs to close. We are sorry for the inconvenience." from windoze
Hi nige777
This is what i use and it seems to work Code:
infile = open(file,"r") for line in infile.readlines(): #do stuff infile.close() |
@TarkaDahl - thanks for the reply unfortunately it was my bad as I needed to be using the excellent 'xlrd' library to be able to work with Excel files
![]() Nige |
| IVEx file extenstion unrecognised. | sindi | Vizard | 2 | 12-10-2009 02:20 AM |
| problems with output to a text file within executable | Saz | Vizard | 1 | 07-01-2009 12:01 PM |
| Problem generating exe file | Anfo | Vizard | 1 | 11-17-2008 05:21 PM |
| Read file....many issues | Uttama_vizard | Vizard | 9 | 07-08-2008 03:16 PM |
| File Management | Uttama_vizard | Vizard | 2 | 07-01-2008 10:44 AM |
