stopping ontimer
My program runs on onkeydown() that are assigned to different def func:. When i switch from func A to func B. A is still running. The reason is I think is becuase of the ontimers that I have associated with it. So is there anyway to stop and ontimer? Any other suggestions to handle this problem?
def funcA():
def calculate():
#CODE
vizact.ontimer2(0,viz.FOREVER,calculate)
vizact.onkeydown('a',funcA)
def funcB():
def speed():
#CODE
vizact.ontimer2(0,viz.FOREVER,speed)
vizact.onkeydown('b',funcB)
You could try this to keep only one timer active at a time.
def calculate():
print 'calculate'
def speed():
print 'speed'
timer1 = vizact.ontimer2(1,viz.FOREVER,calculate)
timer2 = vizact.ontimer2(1,viz.FOREVER,speed)
timer1.setEnabled(viz.OFF)
timer2.setEnabled(viz.OFF)
def funcA():
timer1.setEnabled(viz.ON)
def funcB():
timer2.setEnabled(viz.ON)
Is there a way to use the same key to turn on and turn off the same function?
IE. If I hit 'a' to enable def calculate() then I hit 'a' again to disable def calculate(). I have the idea I think for it. Which would be to have a bool value and then change it from true to false and have if else statements to check it. Could be wrong thats why Im asking. |
You could use viz.TOGGLE so that each time you press the key the timer will change states and your function will either start or stop being called
def funcA():
timer1.setEnabled(viz.TOGGLE)
def funcB():
timer2.setEnabled(viz.TOGGLE)
i have an application where i have my 3d human model walking but i want it to freeze...or pause how can i do that.
| Thread Tools | |
| stopping a function | durf | Vizard | 1 | 03-31-2009 05:45 PM |
| stopping a goto() | vsully | Vizard | 1 | 01-24-2006 02:43 PM |
| partially stopping tracking | vsully | Vizard | 1 | 01-12-2005 10:02 AM |
