Old 03-01-2008, 12:59 PM
Jerry Jerry is offline
Reading in parameters with a published exe
I have a script which reads parameters in from a text file. This is so that
the user can modify the parameters in the file without having to
run Vizard and modify them in the script.
The problem is that when I publish the script to an exe the modified parameter
file is no longer read. It always uses the values of the parameters in effect
when the script was published.
Is there any way to make a published exe read in parameters from a file
when it runs?
Old 03-03-2008, 10:46 AM
Is the input file in the same directory as the EXE? If so, you can use the viz.publish.path option to get the path to the EXE, and prepend it to the filename. Example:
filename = 'input.txt'
#Prepend publish path to filename
if int(viz.getOption('viz.publish',0)):
	filename = '/'.join([viz.getOption('viz.publish.path'),filename])
f = open(filename,'r')
displayhtml did not work after published as EXE felixchc Vizard 5 10-18-2006 02:33 AM
csv reading kgarr Vizard 1 02-27-2006 01:02 PM
A simple Plug_in for reading data from serial port sled Plug-in development 0 08-12-2003 10:52 AM
