Old 08-25-2016, 06:47 PM
Vaquero Vaquero is offline
Question saving proximity events (onEnter,onExit) to file
Hey!
I've scripted an experiment based on the experiment framework in the examples. I have set up my sensor and targets and added them to the manager. Now I want to save the onEnter and onExit events to a file only when the experiment is in the testphase , but I'm lost on how to do that.
def EnterSensor(e):
    print 'Enter',e.sensor.name, contactManager.getActiveTargets(sensor=e.sensor) #DEBUG
def ExitSensor(e):
    print 'Exit',e.sensor.name, contactManager.getActiveTargets(sensor=e.sensor) #DEBUG
manager.onEnter(sensor, EnterSensor)
manager.onExit(sensor, ExitSensor)
Can I just move this code inside the experiment definition ( def experiment(): ) just before yielding the testphase? And instead of printing to console saving to a file that I opened in the experiment function before? I can only test it when I'm back in the lab and on a tight schedule.
Old 08-26-2016, 07:43 AM
You could add a global variable that keeps track of which phase is currently active and check against that. Or you could create two proximity managers and enable one during the initial phases and the other during the test phase:
manager1.setEnabled(viz.OFF)
manager2.setEnabled(viz.ON)
The event object passed to the callback function for the proximity event stores which manager was involved.
Old 08-30-2016, 11:55 AM
Thanks, Jeff, I'll try the second approach. I have another question:
Is there a way to give targets a custom name and retrieve this name with manager.getActiveTargets(sensor=e.sensor)?
Right now this gives me a list like this:
[Target(source=LinkableSource(linkable=__builtin__._VrpnTracker(2), flag=0)), Target(source=LinkableSource(linkable=__builtin__._VrpnTracker(1), flag=0))]
But I'd like to get names for the targets like 'right hand' and 'left hand'. I know I can get the source object of a target, but I haven't found one that has a name attribute.
Old 08-31-2016, 04:24 AM
You can add a custom name attribute to the node:
target.name = 'right_hand'
and get this name in the proximity event callback:
e.target.name
proximity sensor
Fade in and fade out an audio file helena35 Vizard 5 05-30-2016 06:04 AM
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 06:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 01:20 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
