Old 01-21-2013, 09:11 AM
starlingstm starlingstm is offline
Exclamation Using A Projector
Hello. I have a project that involves a projector. The goal is use a web camera for tracking markers' position and orientation, but I want the projector to display the virtual 3D model only. Thus far I have everything working with the web camera, I just need to know if this is possible?
Stephanie
Old 01-25-2013, 12:51 PM
If you don't want to render the camera image set the window argument to None:
camera = ar.addWebCamera(window=None)
Old 03-12-2013, 09:03 PM
Still having issues!!!
Hello, Jeff. I tried the camera function but I'm still not receiving my desired output. That line of coding removes gives a black screen. To help you get a better understanding I've attached a word document with the output I want, the screen shots of the output I'm receiving, and my source code. Thanks in advance for all your assistance.
Design: Virtual Assembly Program
Equipment/ Software: Web Camera, Epson Projector, and ARtoolkit markers
Goal: I need the web camera for tracking purposes only. I want the projector to render the virtual 3D
Model without video feedback from the web camera (NOT THE WEB CAMERA).
Output: I’m getting feedback from both the web camera and projector.
Paths: I tried replacing camera = ar.addWebCamera() with camera = ar.addWebCamera(window=None)
and I receive a black screen and feedback.
Old 03-13-2013, 03:01 AM
Can you post a simple example script that shows the issue you are having?
Old 03-13-2013, 08:21 PM
Sample Source Code
Attached sample code and screen shots of my output thus far. Thanks
Old 03-14-2013, 07:51 AM
Can you start with a simple example and verify that you get the correct output?
#Add ARToolkit extension
ar = viz.add('artoolkit.dle')
#Create camera using first available webcam
#Create a matrix marker with the specified id
marker = camera.addMatrixMarker(0,width=1000)
#Add logo model
logo = viz.add('logo.ive')
#Link logo model to marker sensor
viz.link(marker,logo)
Old 04-05-2013, 02:37 PM
Yes, I get the correct output. Now, how do I bring a projector into the connection and use it to only output my "logo" in an augmented environmnet.
Old 04-05-2013, 05:34 PM
Does your projector work in stereo or mono? If stereo, which kind of stereo input does it require?
If the test application works but your application does not, you'll need to find out where your application is breaking. To do that, start with a simple script, and add code until you see where the problem begins.
shadows in mirror chris_user Vizard 0 02-17-2011 04:37 AM
Use Projector from room.wrl jassel41 Vizard 1 11-18-2010 03:38 PM
multiple shadows using projector theuberk Vizard 13 02-24-2009 03:56 AM
3d projector Vinicius Lima Vizard 21 03-05-2008 04:51 PM
3D Projector Vinicius Lima Vizard 1 08-20-2007 06:52 PM
