Old 07-29-2016, 01:27 PM
Is that possible to create some connection between to sphere?
For example, I add two spheres into Vizard to represent the joints.
However, I want to create a line or some other things which can connect these two joints.
When the position of the joints change, the line will move follow the joints.
Thanks.
Old 07-30-2016, 05:29 AM
You could create an on-the-fly line to connect the two spheres.
Old 07-31-2016, 11:16 AM
import viz,vizact,vizshape, vizmat
grid = vizshape.addGrid()
sphere_0_left = vizshape.addSphere(radius=0.1)
sphere_1_left = vizshape.addSphere(radius=0.1)
So how to connect this two sphere using on the fly
Old 07-31-2016, 07:00 PM
If you want to draw a line, create a layer with viz.lines and use the center point of each sphere as a vertex. You can update the vertex positions as the sphere positions change.
Old 08-01-2016, 09:56 AM
in that way, the system will repeat drawing the line as many as the times of position changes.
is there a way to draw one line and keep updating the position
Old 08-02-2016, 06:03 AM
Yes, once you create the line you can move it like any other object:
import vizshape
viz.clearcolor(viz.SLATE)
vizshape.addGrid()
viz.startLayer(viz.LINES)
viz.vertex(0,0,0)
viz.vertex(0,1,0)
line = viz.endLayer()
line.setPosition([2,0,7])
line.color(viz.RED)
Old 08-02-2016, 09:11 AM
import vizshape
vizshape.addGrid()
viz.vertex(0,0,0)
viz.vertex(0,1,0)
line.color(viz.RED)
Is there a way to change the position of line only by change the vertex of it?
In the code you gave to me, the length of the line is fixed, is that possible to get a line which will change its length according to the position of vertex?
Old 08-08-2016, 01:43 PM
import vizshape
vizshape.addGrid()
viz.vertex(0,0,0)
viz.vertex(0,1,0)
line.color(viz.RED)
can you help me to solve my last question?
Old 08-08-2016, 09:59 PM
Yes, you can modify vertices to change the length of the line. Take a look at the changing vertices page from the on-the-fly section. Does this help answer your question?
Create object with position relative to user head, but cannot be obstructed by others Notch Vizard 2 03-03-2014 07:16 AM
Create a clipping box pswaney Vizard 1 03-01-2013 12:19 PM
How to create AMTI AccuGait force plate plug-in using serial port connection? manueleh Plug-in development 0 09-20-2012 01:22 PM
Dynamic Position and Radius of Sphere hotshotiguana Vizard 1 03-23-2011 12:53 PM
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 05:34 PM
