Old 07-24-2015, 10:17 AM
ichitaka ichitaka is offline
Oculus DK2 image warping
Hello everybody!
Currently i'm working on a project where i'm using the oculus rift dk2 with a ppt x4 tracking system. All implemented in vizard 5.
My implementation of the rift sadly causes some kind of image warping and i don't know what kind of setting it is that i had set wrong. Here some screenshots(head was turned on second image to shop the difference):
http://imgur.com/a/EV0Wm
My code for the rift implementation is:
if enable_oculus:
	import oculus
	viz.setOption('viz.glFinish',1)
	viz.mouse.setVisible(False)
	hmd = oculus.Rift(window=viz.MainWindow, autoDetectMonitor=True)
	sensor = hmd.getSensor()
	viz.window.setFullscreen(True)
	if enable_ppt:
		init_ppt()
		link = viz.link(sensor, viz.MainView)
Old 07-24-2015, 01:02 PM
It's not clear to me what the image warping you're referring to is. What version of the Oculus SDK are you using? Are you running in Direct HMD or Extend HMD to desktop mode? Does this also occur with the oculusExample.py script included with Vizard?
Multiple post-process effects with oculus rift lklab Vizard 2 03-13-2015 02:48 PM
Oculus runtime disrupts clustering to mirror DK2 display performlabrit Vizard 1 01-23-2015 08:00 AM
Oculus DK1 and DK2 in Vizard 5 Jeff Vizard 3 10-02-2014 12:00 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 07:17 AM
