Old 04-05-2015, 08:31 PM
cmeans cmeans is offline
Vizard/Kinect Gesture Reader Code
I'm a beginner to Vizard. I'm trying to write code that will recognize when the user has their right arm in a right angle. I'm using vizmat.AngleBetweenVectors() to try and get the angle between the right shoulder and the right hand. To my mind, if you hold your arm at a right angle, it will read ~90 degrees.
I'm encountering two problems:
1) As I move my arm back and forth, holding it at a right angle, the degrees change.
2) It's not reading 90 degrees.
Here is my code:
def RightArmAngle():
    RShoulder = vrpn.addTracker('Tracker0@localhost',RIGHTSHOULDER)
    RSpos = RShoulder.getPosition()
    RHand  =vrpn.addTracker('Tracker0@localhost',RIGHTHAND)
    RHpos = RHand.getPosition()
    RHvec = viz.Vector(RHand.getPosition(),normalize = True)
    RSvec = viz.Vector(RShoulder.getPosition(),normalize = True)
    RAVector=vizmat.AngleBetweenVector(RSvec,RHvec)#RAVector and RAAngle return the same value
    RAAngle = vizmat.AngleBetweenVector(RSpos,RHvec)
    print("r elbow:",RHvec)
    print("r shoulder:",RSvec)
    print("position Angle:", RAAngle, "vs RAVector",RAVector)
    print("new")
vizact.ontimer(1,RightArmAngle)
Here are some diagrams and my outputs:
Raised Arm, Turned to Side. Vector Returned: ~31
Right-Angled Arm, Held in Front, Vector Returned: ~23
Name:	rightish angle.png
Right-Angled Arm, Held to Side, Vector Returned: ~16
I'm confused as to how thought this would be a simple way. Should I try to make a triangle instead? Or should I just be returning one Euler value and finding the angle from that?
Old 04-09-2015, 07:01 PM
You would need to track three points (hand, elbow, and shoulder) in order to get two vectors and then calculate the angle between those.
angles, kinect, movement, vizard
How to make my code more efficent. Queenss_RA Vizard 2 05-13-2013 10:22 AM
Using Sphinx to generate code documents nabrahamson Vizard 0 10-31-2011 08:38 AM
Suggestion: Code Browser kopper Vizard 5 05-23-2011 04:39 AM
Any ideas on linking chess 3ds file with source code? djones1010 Vizard 1 04-24-2009 10:56 PM
Trying to integrate Source Code with Vizard djones1010 Vizard 1 03-10-2009 03:58 PM
