Old 06-07-2012, 05:57 AM
Rudi Rudi is offline
Cave GUI
We're working on a project to simulate a product for the year 2022.
For this we are using the CAVE and Vizard.
We've bumped into a problem we've made a gui with the gui menu in vizard and it's working fine when we launch it on our desktop. But as soon as we try it out in the cave it displays on each screen and it doesn't work with viz.go
When we comment out viz.go the functions wont work and the gui shows on every wall when we want it to be displayed on just one (the middle one).
We've searched the web but we couldn't find anything regarding this problem.
We did ask the local representative (Sjaak Verwaaijen) but he couldn't help us out.
TL;DR: How can we display the gui on just a single screen and not on all 4 inside the CAVE. And how can we use viz.go so we can vizact to the menu buttons?
With kind regards,
ReLive
Old 06-11-2012, 05:57 PM
Are you using a cluster setup to run the CAVE? If so, you can use cluster masks to hide the GUI on all the machines except the one rendering the middle wall.
Old 06-14-2012, 05:12 AM
Yes, we are using a cluster setup but we don't know how to adress just a screen. How can we use the cluster masks?
Edit:
Nevermind, we found the following link and are going to implement it in a moment.
http://docs.worldviz.com/vizard/comm...er/setMask.htm
Old 06-12-2012, 01:59 AM
Andy Andy is offline
I have the same problem and I’m searching for a solution. We are using a curved screen so each projection is quite narrow and they are blending with each other. My approach would be to create a surface (transparent), which flies in the virtual room and shows GUI.
Is something even conceivable? At the moment it is only an idea.
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 01:50 PM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 05:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 11:12 AM
CAVE, navigation, tracked wand, coordinate systems JimC Vizard 6 10-09-2009 01:43 PM
Wiimote in 4 sided Cave Sjaak Vizard 2 05-20-2009 02:05 PM
