Old 12-09-2009, 09:26 PM
jincheker jincheker is offline
Is there any open file GUI
Can I build a GUI in vizard, like below, that allow user to open and choose some files and import them into vizard?
Old 12-10-2009, 09:42 AM
I mean build a button, and when click the button, it can call an open file GUI in which people can browse and choose files to be open?
Old 12-10-2009, 03:11 PM
hosier hosier is offline
There's an example over in the Vizard 2.5 forum. Here's a link to it:http://forum.worldviz.com/showthread...light=win32gui
I've tried it under Vizard 3 and it works, no problem.
Aaron
Old 12-11-2009, 02:53 PM
Thumbs up
Aaron
Thanks hosier
Old 07-23-2010, 06:44 AM
nige777 nige777 is offline
Question
Sorry for bumping this thread but when I attempt to use the code in this example I get this error:
** Load Time: 0.01 seconds
  File "<string>", line 11, in ?
  File "Vizard2.py", line 3, in ?
    inFileDlg = win32ui.CreateFileDialog(1, '', 'foo.txt')
TypeError: None is not a valid string in this context
I have used the exact code in the given example but still no joy
I really need to be able to navigate to and open various files and this seemed the ideal way to do it except I can't get it to work!! I'd be really grateful for any ideas regarding this,
Cheers
Old 07-23-2010, 09:07 AM
Ok, I'm getting somewhere here I think. Here's what I am using now:
def ChooseFile():
	"""You can find documentation for CreateFileDialog at the following site:
		http://aspn.activestate.com/ASPN/docs/ActivePython/2.5/pywin32/win32ui__CreateFileDialog_meth.html"""
	parent = win32ui.CreateWindowFromHandle(viz.window.getHandle())
	dlg = win32ui.CreateFileDialog(1,'','',0,'',parent)
	if dlg.DoModal() == win32con.IDOK:
		file = dlg.GetFileName()
		inFileName  = dlg.GetPathName()
		print file
		print inFileName
- Thanks farshi
However, what I would really like to do is open the selected file, so I tried adding:
		FILE = open(file, 'r')
		for line in FILE:
			print line
- but all I get is
ÐÏࡱ
So my question is - what am I doing wrong here, I just want a participant to be able to select a file which is then read in / parsed into useful chunks of data.
Also when exiting winviz after running this I get a - "winviz.exe has encountered a problem and needs to close. We are sorry for the inconvenience." from windoze
Old 07-23-2010, 09:28 AM
Hi nige777
This is what i use and it seems to work
	infile = open(file,"r")
	for line in infile.readlines():
		#do stuff
	infile.close()
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 02:20 AM
problems with output to a text file within executable Saz Vizard 1 07-01-2009 12:01 PM
Problem generating exe file Anfo Vizard 1 11-17-2008 05:21 PM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 03:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
