Old 05-11-2008, 03:22 PM
Lotar Lotar is offline
Hand model collision detection.
is it possible to detect collision between specific bone of the 5DT glove's hand model and some other objects ? When I try to apply collision mesh directly on a specific bone, it says that VizBone object has no attribute collideMesh. Is there some other way, then ?
Old 05-12-2008, 05:14 PM
You cannot perform collision on bones, only the entire avatar mesh. Are you trying to detect when the fingers touch something? If so, you can create an empty group node with a collision shape similar to the finger, then before performing collision detection you can manually place the group node at the current finger bone location. Either way, if you can describe what you are trying to accomplish I can provide you with some sample code.
Old 08-29-2008, 05:43 PM
rubberpimple rubberpimple is offline
Hi farshizzo,
I'd love to see the code for this. I'm trying to do collision detection between a hand model and specific child nodes of a parent object. Did I read somewhere that I can only do collision detection on nodes that are children of viz.WORLD?
David
Old 04-23-2009, 08:44 AM
Moh200jo Moh200jo is offline
Originally Posted by rubberpimple View Post
Hi farshizzo,
Hi David,
Have you got the code of bone collision?
Thanks in advance.
Old 04-23-2009, 11:26 AM
Here's the thread that has a response to this question
Old 04-23-2009, 12:08 PM
I have tried with the following code; does not work
HTML Code:
viz.add('tut_ground.wrl')
#Add the ground and an avatar.
avatar = viz.addAvatar( 'vcc_female.cfg' )
ball=viz.add('ball.wrl')
ball.setPosition(0,0.1,9)
ball.collideSphere()
ball.enable(viz.COLLIDE_NOTIFY)
walk=vizact.walkTo([0,0,8.99])
avatar.addAction(walk)
boneCollide = viz.addGroup()
boneCollide.collideBox([.5,.1,.5])
foot=avatar.getBone('Bip01 R Foot')
boneCollide.setPosition(foot.getPosition(viz.AVATAR_WORLD))
boneCollide.setQuat(foot.getQuat(viz.AVATAR_WORLD))
nodes = viz.phys.intersectNode(boneCollide)
for n in nodes:
    print 'bone collided with',n
Old 04-23-2009, 01:18 PM
If you want to have collisions with the avatar's foot I think the code that Farshizzo posted in this thread will help. In that example a collision box is linked to an avatar's hand.
Collision detection with haptic pen mjabon Vizard 3 01-17-2008 07:35 PM
collision detection? Colin Vizard 5 05-16-2007 05:52 PM
problem with collision detection paulpars Vizard 6 06-09-2006 07:03 PM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 05:47 AM
Collision Detection for Hierarchies of Objects vjosh Vizard 1 04-15-2005 06:46 PM
