Old 03-06-2007, 08:09 AM
Steve_HT Steve_HT is offline
fastrak
I'm trying to use the Polhemus fastrak unit. I have the unit connected on COM1 and a cyberglove on COM2. 'Cyberglove.dls' seems to work fine, but 'fastrak.dls' is unable to connect to the device, even though it's clearly available and running in the Immersion software.
What am I missing here?
I've also tried "Patriot_HeadHand" with both the patriot plug-in and the fastrak plug-in with no luck.
Old 03-06-2007, 09:04 AM
Did you specify the port before adding the fastrak.dls sensor? Your code should look something like this:
PORT_FASTRAK = 1
fastrak = viz.add('fastrak.dls')
Old 03-06-2007, 02:00 PM
That doesn't seem to help
Old 03-06-2007, 02:50 PM
Are you getting an error message? If so, can you please post it.
Old 03-07-2007, 06:15 AM
The code:
glove = viz.add('cyberglove.dls')
PORT_FASTRAK=1
polhemus = viz.add('fastrak.dls')
The Error:
** Loading newHandTest.py
cyberglove.dls CyberGlove Driver v1.0
fastrak.dls Polhemus Fastrak v1.0
** ERROR: Failed to connect to Polhemus Fastrak
Old 03-07-2007, 09:55 AM
Is the unit set to communicate over serial at a baud rate of 115200? You can check by making sure switches 1, 2, 3, 5, and 8 are UP.
Old 03-07-2007, 10:17 AM
Yep, they are set. As I said, it communicates just fine with the Immersion Technologies software. Is there perhaps a Polhemus driver that I'm missing, or something like that?
Old 03-07-2007, 10:42 AM
If you are connecting the Fastrak over USB, then you do need to install a driver. But, as far as I remember, you don't need any additional drivers when connecting over serial.
You mentioned that the Fastrak communicates fine with the Immersion software. Did you mean that it communicates fine with the Polhemus software? The CyberGlove is an Immersion product, not the Fastrak.
Old 03-07-2007, 11:58 AM
Yeah, I uploaded new Polhemus firmware onto the Fastrak, but otherwise have not been using any Polhemus at all. My communications are through the standard serial port.
