Old 05-27-2015, 08:31 PM
jizh1000 jizh1000 is offline
How to set the viewpoint as the proximity target in a Vizconnect configuration?
In the vizard documentation, there is a way for setting the main view as the proximity target:
target = vizproximity.Target(viz.MainView)
But it does not work in the script generated by Vizconnect. I wonder if it is possible to set the viewpoint as the proximity target using Vizconnect?
Thanks.
Proximity Sensing Using Kinect JamesCakes Vizard 6 06-24-2016 06:52 AM
Orientation selective (Viewing Vector) Proximity Sensor lmGehrke Vizard 2 03-17-2015 01:31 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
vizproximity hint - debug 2D areas related to a source only after adding a target! fordprefect Vizard 1 12-15-2014 01:37 PM
Avatar w/ hat cannot look at viewpoint TrashcanPatrol Vizard 5 08-19-2008 09:26 AM
