Old 06-02-2016, 07:25 AM
JB_HP_Viz JB_HP_Viz is offline
How to set offset for ART SmartTrack
I have the ART SmartTrack working in the Christie HoloStation CAVE but when you put the tracked 3D glasses on it doesn't look like the correct view point for the user. It looks like the users eye point should be set to be higher. So I thought maybe the offset needs to be changed.
Since I was not able to use Vizconnect to setup the tracker is there a way to change the offset like you can in Vizconnect for the tracker (I attached the image that shows how you change settings in Vizconnect, but I didn't see information on how to do if not using Vizconnect to setup Tracker)?
Below I included the CAVE dimensions information. With the Holostation CAVE the floor sits 32 inches off the ground
# Declare constants defining the CAVE dimensions
#height from floor to display 32 inches
#height of display 42.875 inches
W = 1.724       # 67.875 inches wide
H = 1.902       # 74.875 inches tall
#DF = 1.08       # 42.5 inches deep for floor
D = 1.438       # 56.625 inches deep
W2 = W/2.0
C0 = -W2,H,0     # Front  Wall: C1,C2,C5,C6
C1 = -W2,H,D     # Left   Wall: C0,C1,C4,C5
C2 = W2,H,D      # Right  Wall: C2,C3,C6,C7
C3 = W2,H,0      # Bottom  Wall: C5,C6,C4,C7
C4 = -W2,0,0
C5 = -W2,0,D
C6 = W2,0,D
C7 = W2,0,0
#Create front wall
FrontWall = vizcave.Wall(   upperLeft=C1,
                             upperRight=C2,
                             lowerLeft=C5,
                             lowerRight=C6,
                             name='Front Wall' )
#Create left wall
LeftWall  = vizcave.Wall(   upperLeft=C0,
                             upperRight=C1,
                             lowerLeft=C4,
                             lowerRight=C5,
                             name='Left Wall' )
#Create right wall
RightWall = vizcave.Wall(   upperLeft=C2,
                             upperRight=C3,
                             lowerLeft=C6,
                             lowerRight=C7,
                             name='Right Wall' )
#Create bottom wall
BottomWall = vizcave.Wall(  upperLeft=C5,
                             upperRight=C6,
                             lowerLeft=C4,
                             lowerRight=C7,
                             name='Bottom Wall' )
Offset position of link/attached object MissingAFew Vizard 3 04-13-2015 05:15 PM
Introducing a rotation offset into a link EnvisMJ Vizard 1 11-13-2013 05:51 AM
Textures not loading properly and offset window TarkaDahl Vizard 2 05-18-2010 01:54 PM
window offset on windows 7 IGoudt Vizard 0 02-09-2010 07:06 AM
Offset Problem Elittdogg Vizard 1 09-15-2009 06:28 AM
