Old 06-05-2013, 11:17 AM
mshukun mshukun is offline
Cube Map Coordinates
Might anyone know what coordinate system is applied in the cube map? The code below was kindly provided to me using this forum, but I need to know the actual coordinate system used in the cube map in order to perform further downstream processes. For instance, if a spherical coordinate system is used in the cube map, how can I find radius of the sphere? On the other hand, if a cube coordinate system is used, how can I ascertain the height, width and depth of the cube map? (Thanks in advance for any assistance you can provide in this regard, which is greatly appreciated.)
import vizmat
import vizshape
env = viz.addEnvironmentMap('Farm2A.jpg')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
viz.link( viz.Mouse , viz.addTexQuad(viz.SCREEN,texture=viz.add('crosshair.png')) )
viz.mouse.setVisible(viz.OFF)
def placeMarker():
line = viz.MainWindow.screenToWorld(viz.mouse.getPosition())
pos = vizmat.MoveAlongVector(line.begin,line.dir,40)
shape = vizshape.addCircle()
shape.color(viz.GREEN)
shape.billboard()
shape.setPosition(pos)
print shape.getPosition()
#place a marker when the left mouse is pressed
vizact.onmousedown(viz.MOUSEBUTTON_RIGHT,placeMarker)
import vizcam
vizcam.PanoramaNavigate()
Image: Spherical coordinate vs Cube coordinate
http://screencast.com/t/hSkab1MNKk
Texture Coordinates in a Cube Map mshukun Vizard 2 05-10-2013 01:31 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 07:17 AM
How do coordinates in IS900 thransform into coordinates in vizard's world jacky Vizard 1 08-11-2011 11:44 AM
viz.vertex coordinates lilio Vizard 6 05-16-2009 05:36 PM
Inertia Cube bstankie Vizard 1 03-24-2003 12:00 PM
