Old 02-12-2009, 11:21 PM
nlfrnassimi nlfrnassimi is offline
Unhappy moving and object by mouse but don't know how to stop the movement
my code is to select a ball and move it by mouse, I want to click a key and the ball will remain in that position, but have no idea how to do it.
please help
this is my code :
viz.clearcolor(0.5,0.5,1)
ground.disable(viz.PICKING)
soccerball1 = viz.add('soccerball.ive')
soccerball2 = viz.add('soccerball.ive')
soccerball3 = viz.add('soccerball.ive')
soccerball1.translate(-1,1.5,3)
soccerball2.translate(0,1.5,3)
soccerball3.translate(1,1.5,3)
viz.mouse(viz.OFF)
def mouseclick(button):
global ball
pickObj = viz.pick()
if pickObj.valid():
ball = pickObj
def mymouse(e):
global ball
if not ball:
return
ball.setPosition((e.x-0.5)*3,e.y*3.5,3)
viz.callback(viz.MOUSEDOWN_EVENT,mouseclick)
viz.callback(viz.MOUSE_MOVE_EVENT,mymouse)
Old 02-13-2009, 02:07 AM
moooh moooh is offline
You will just have to set the ball value to None and the ball should stay at its current position as your code already checks whether or not a ball is active before trying to move it.
You could alter the mouse down function to pick up the ball if none is selected and drop the ball if currently holding one, like this:
    global ball
        if not ball: #we are not holding a ball, try to pick one up
            if pickObj.valid():
                ball = pickObj
        else: #we were holding a ball, drop it
            ball = None
or instead of changing the mousedown function you could make it so that pressing a key on the keyboard drops the ball:
def dropBall:
    global ball
    ball = None
vizact.onkeydown( 'd', dropBall )
This will drop the ball when the d key is pressed.
Old 02-15-2009, 07:02 PM
mouse wheel problem
Thanks for your help, it works perfect. I have another problem.
I want to assign mouse wheel to be able to move my selected ball in depth. But I have no idea how to do it. Please help.
Old 02-17-2009, 06:33 AM
DrunkenBrit DrunkenBrit is offline
Maybe something along the lines of:
diffInZ = 3.0 # Value to add/subtract to Z position of selected ball
def onMouseWheel(dir):
    global ball # Same ball object selected from previous mouse move callback
        # Check 'ball' is valid/one selected from previous callback
               ballPos = ball.getPosition()
               addZ = -3.0
               # If wheel is moving forward, make positive, else leave as negative
               if dir > 0:
                 addZ = 3.0
            ball.setPosition( ballPos[0], ballPos[1], ballPos[2] + addZ )
viz.callback(viz.MOUSEWHEEL_EVENT,onMouseWheel)
Software Developer
Virtalis Ltd.
www.virtalis.com
Old 02-18-2009, 08:39 PM
Thanks for your great help. It worked great.
Just that when I move the ball in depth and then try to move the mouse the ball comes back to front. do you know how should I solve this problem?
Old 02-19-2009, 01:35 AM
Yes at this line of code
you have coded to always put the ball at z-coord 3 when moving the mouse. If you want to get the z-coord unaltered by the regular mouse movement you will have to change it to use the z-value from the ball's current position
pos = ball.getPosition() #get the current position
ball.setPosition((e.x-0.5)*3,e.y*3.5, pos[2] )  #pos[2] is the z-coord for the current position
Old 02-19-2009, 01:36 AM
Are you resetting the Z position of the selected ball in the mouse movement callback which moves the ball's X and/or Y position?
Software Developer
Virtalis Ltd.
www.virtalis.com
Old 02-20-2009, 12:48 AM
Thanks for your help mooh. it works perfect.
Old 04-26-2009, 08:23 AM
nasr nasr is offline
could u plz help me...i am also developing similar application
i am also practising to develop a similar application which u come across with. i want to create a virtual room with a table and some books on it. along with a chair and i want to move, rotate the chair with the help of mouse. can u plz post the code for picking up the objects and moving, rotating, thanking you..
please help
this is my code :
viz.mouse(viz.OFF)
global ball
if pickObj.valid():
ball = pickObj
def mymouse(e):
global ball
if not ball:
return
how can I stop an action? nlfrnassimi Vizard 4 02-13-2009 01:59 AM
Pick porblem with arrays shivanangel Vizard 3 08-27-2007 11:10 AM
Moving view with object Xliben Vizard 2 07-25-2005 06:36 PM
