Thread Tools Rating: Thread Rating: 4 votes, 2.00 average. Display Modes
Old 10-30-2024, 01:24 PM
dyagbobli dyagbobli is offline
Registered User
Angry Issue Running Cluster: Projection PC Master + Headset VR PC Clients
I am trying to use Vizard cluster client with 2 Headset VR PCs running as clients and a Projection VR PC running as the Master. Every time I run the scripts from my Master PC to the clients, the communication is established, however, I get the following error message: "WARNING: Quad buffer stereo is not supported or enabled on your graphics card".
For context, I have NVIDIA RTX Series GPU on my Master and Client PCs.
Old 09-11-2025, 10:38 AM
Hi, you can try opening up your vizconnect hardware configuration file, then going to Advanced options- Display, click on "Settings" and change the dropdown to not use quad buffer stereo. Let me know if that works.
cluster client, cluster master, clustering
Cluster Master Load Options apenngrace Vizard 1 02-03-2023 04:18 PM
"Launching in cluster master mode." when cluster mode disabled jpriede Vizard 2 02-12-2013 03:33 PM
No rendering on Cluster Master victorqx Vizard 1 06-04-2012 09:42 AM
Automatically set Cluster Master Settings pcatalano Vizard 2 01-28-2011 02:09 PM
Cluster Help videcuk Vizard 12 09-21-2007 03:14 PM
