Old 08-04-2016, 01:43 PM
parisa parisa is offline
Registered User
Position
Hi everyone
I am new here and I have a Question:
I am navigating in Piazza using my keyboard. How can I ask vizard to return my position every second to me in [x y z] format and also like a drawing format? (like a picture of a path i took like GPS for example)
I would appreciate it if someone help me
Thank you
Old 08-05-2016, 04:32 AM
rajnishv rajnishv is offline
Hi Parisa,
You may use the "node3d.getPosition()" inside the Update(): fuction called every 0 seconds using the timer function:
def myPostion():
mynode.getPostion("co-ordinate system") #you may use ur viewpoint as mynode to get ur position.
vizact.timer(0,myPosition)
and to draw you may use pls c to the link:
http://docs.worldviz.com/vizard/Changing_on-the-fly.htm
Regards
Mr.Rajnish Vishwakarma
position, positional tracking, return position, vizard
Changing parent without changing absolute global position? The SundanceKid Vizard 2 05-23-2014 03:43 PM
Getting updated position Anastaggra Vizard 1 02-01-2014 01:15 AM
Set Mouse Position javadi Vizard 2 11-19-2013 04:59 AM
How to pass only 1 axis of the position signal from the source to the dest in a LINK? Zhi Vizard 2 04-04-2013 08:28 AM
Getting Position Lynnifer Vizard 1 07-16-2012 10:49 AM
