Old 04-20-2016, 09:06 AM
jelly jelly is offline
animation path problem - coordinates not resetting
Dear Jeff,
I am sorry, but I am still having problems with my animation path from here http://forum.worldviz.com/showthread.php?t=5695 Since it is a different problem, I decided to open a new thread.
The problem is that after the trial (and the animation) run once, the other three times they run, the coordinates are not reset. To find out what happens I added two lines to find out the cooridnates (red below), at those points where I believe I should get the starting and end positions. The output gives me this, which is indeed very strange:
now
[-6.400000095367432, 0.0, -8.0]
[0.0, 1.399999976158142, 5.0]
now
[0.0, 0.0, 5.0]
[0.0, 0.0, 5.0]
now
[0.0, 0.0, 5.0]
[0.0, 0.0, 5.0]
now
[0.0, 0.0, 5.0]
[0.0, 0.0, 5.0]
Only the very fist line is correct, since that is the starting position. In another version I tried removing all control points at the end of the trial and adding them at the beginning. But that does not seem to help What happens with the coordinates for the animation and the viewpoint during the other 3 trials? It seems that the viewpoint is not reset, but that it takes and keeps the very last coordinate which is also relative to the path not absolute in the coordinate space.
I would be so grateful for your help!
I have updated the code below:
import viz															#Needed to generate a world.
import viztask														#Needed to control the experiment structure.
viz.mouse.setVisible(viz.OFF) 										#Stops the mouse appearing on the screen.
viz.mouse.setOverride(viz.ON)										#Stops Vizard navigation using the mouse.
viz.clearcolor(viz.BLACK)
#Set the start position:
startPos = [-6.4,0,-8]
### Add all the resources. ###############
maze1 = viz.add('Objects/Maze_1.dae')
maze1.visible(viz.OFF)
#Add a sky with an environment map.
env = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
dome = viz.add('skydome.dlc')
dome.texture(env)
view = viz.MainView
view.eyeheight(1.4)
view.setPosition(startPos)
view.collision(viz.ON)
viz.collisionbuffer(.8)
viewNode = viz.addGroup()
viewLink = viz.link( viewNode, viz.MainView)
viewNode.setPosition([-6.4,0,-8])
##Animation path
pathMaze1 = viz.addAnimationPath()
#Add control points to the path, along with their time stamp.
pathMaze1.addControlPoint(0,pos=(-6.4,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(2,pos=(-6.4,0,-8),euler=(90,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(4,pos=(0,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(8,pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
#Duation of animation
pathMaze1Duration = pathMaze1.getDuration()
#Loop the path in a swinging fashion (point A to point B to point A, etc.).
pathMaze1.setLoopMode(viz.OFF)
def maze1trial():
	print 'now'
	print view.getPosition(mode = viz.ABS_PARENT)
	pathMaze1.reset()
	maze1.visible(viz.ON)
	viewNode.setPosition(startPos)
	link = viz.link(pathMaze1,viewNode)
	yield pathMaze1.play()
	yield viztask.waitTime(pathMaze1Duration)
	link.remove
def masterFunction():
	for x in range(4):
		yield maze1trial()
viztask.schedule(masterFunction())
Old 04-20-2016, 06:35 PM
Try placing the print statement after the path is reset:
pathMaze1.reset()
Also, the view is linked to a viewnode and the viewnode is linked to the path. It seems like you could simplify the code and remove all references to the viewnode here.
Old 04-22-2016, 09:14 AM
Thank you very much!
It worked now, though I am not sure what did the trick! I simplified it and it now looks like this:
dome.texture(env)
view = viz.MainView
view.eyeheight(1.4)
##Animation path
pathMaze1.addControlPoint(2, pos=startPos,euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(4, pos=startPos,euler=(90,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(6, pos=(0,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(8, pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
def animation():
	link = viz.link(pathMaze1,view)
	pathMaze1.play()
	pathMaze1.reset()
def maze1trial():
	print 'now'
	yield animation()
	for x in range(4):
		yield maze1trial()
Old 04-22-2016, 09:23 AM
I am afraid that the problem continues as soon as I introduce further animation paths. I changed the one I had before to get the following: a trial triggers an animation that moves the viewpoint through a maze until a certain point when it wiats for an arrow key. Once a key is pressed it triggers one of two possible animations (going through left or right door). After this, immmediately, the next trial should start.
Problem 1:
This almost happens, only that the second trial starts at the point where the last door was, etc. I tried resetting the animation paths at various points and nothing seems to help.
Problem 2:
For some reason, it the right arrow key seems to not work. This seems to be a problem of the if statement, because even if I replace the arrow key with the space bar, it does not take the "elif" statement...
I would highly appreciate any pointers in the right direction!
#Load a maze and make it invisible
dome.texture(env)
#Parameters for the viewpoint
view = viz.MainView
view.eyeheight(1.4)
##Animation path
pathMaze1.addControlPoint(2, autoRemove = True, pos=startPos,euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(4, autoRemove = True, pos=startPos,euler=(90,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(6, autoRemove = True, pos=(0,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(8, autoRemove = True, pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
#Duation of animation path
#animation paths for choosing doors
pathDoorLeft = viz.addAnimationPath()
pathDoorLeft.addControlPoint(0, autoRemove = True, pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
pathDoorLeft.addControlPoint(1, autoRemove = True, pos=(0,0,5),euler=(-10,0,0),scale=(2,2,2))
pathDoorLeft.addControlPoint(2, autoRemove = True, pos=(-1.3,0,10),euler=(-10,0,0),scale=(2,2,2))
pathDoorLeftDuration = pathDoorLeft.getDuration()
pathDoorRight = viz.addAnimationPath()
pathDoorRight.addControlPoint(0, autoRemove = True, pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
pathDoorRight.addControlPoint(1, autoRemove = True, pos=(0,0,5),euler=(10,0,0),scale=(2,2,2))
pathDoorRight.addControlPoint(2, autoRemove = True, pos=(1.3,0,10),euler=(10,0,0),scale=(2,2,2))
pathDoorRightDuration = pathDoorRight.getDuration()
def chooseDoor():
	yield viztask.waitKeyDown(viz.KEY_LEFT or viz.KEY_RIGHT)
	if viz.key.isDown(viz.KEY_LEFT):
		link = viz.link(pathDoorLeft,view)
		pathDoorLeft.play()
		yield viztask.waitTime(pathDoorLeftDuration)
	elif viz.key.isDown(viz.KEY_RIGHT):
		link = viz.link(pathDoorRight,view)
		pathDoorRight.play()
		yield viztask.waitTime(pathDoorRightDuration)
def animation():
	pathMaze1.play()
	#pathMaze1.reset()
def maze1trial():
	print 'new trial'
	pathMaze1.reset()
	pathDoorRight.reset()
	pathDoorLeft.reset()
	print view.getPosition(mode = viz.ABS_PARENT) #starting point of animation just for control purposes
	yield animation()
	print view.getPosition(mode = viz.ABS_PARENT) #ending point of animation just for control purposes
	yield chooseDoor()
	for x in range(4):
		yield maze1trial()
Old 04-25-2016, 04:16 AM
The arrow key problem seems to be a problem in my particular case, but not necessarily acoding mistake. This simple code shows that, for some reason only the left arrow key works.
import viztask
def key():
		print '"RIGHT" key is down'
	elif viz.key.isDown(viz.KEY_LEFT):
		print '"LEFT" key is down'
viztask.schedule(key())
This is not a problem of my keyboard though, because the key works otherwise. It must somehow be related to Vizard. Any ideas what it could be?
As for the second problem with the animation paths:
I have reset all three animation paths at the beginning of the trial and re-established the link. I have actually tried an impossible number of combinations, where I resert the animations at different locations (inside each of the functions, same goes for the link and resetting the viewpoint at the start location. Each time things turn out different, sometimes the coordinates are so much off, it is impossible to track what is going on. Other times, they are only slightly off and in some cases I have animations that add the paths of the second animation to the first one, hence creating one long one. This is a clue that sometimes the animation paths maybe do not reset?
The closes I got was with this code (please see below). This works almost perfectly. Only the first control point of the main maze animation path is a bit off. Firts time, it runs perfectly, the next times it always takes the same last coordinates of the end control point of the left door animation path. So the biggest clue for me to understand is where do I reset the door animation best? In the chooseDoor function, in the trial function? I have tried them all..
import viztask
dome.texture(env)
view = viz.MainView
view.eyeheight(1.4)
##Animation path
def chooseDoor():
		pathDoorLeft.play()
		link.remove()
		link.remove()
def animation():
	pathMaze1.play()
	#pathMaze1.reset()
def maze1trial():
	print 'new trial'
	pathMaze1.reset()
	yield animation()
	yield chooseDoor()
	link.remove()
	for x in range(4):
		yield maze1trial()
Thank you very much in advance for your help!
Old 04-25-2016, 10:33 PM
The viztask.waitKeyDown command requires a list of keys. Try the following instead:
yield viztask.waitKeyDown([viz.KEY_LEFT,viz.KEY_RIGHT])
problem with path animation jelly Vizard 5 04-20-2016 06:15 AM
Road Animation Path vserchi Vizard 4 11-12-2015 09:29 AM
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 04:23 PM
speed on animation path whj Vizard 8 11-17-2008 07:41 PM
another bezier animation problem masaki Vizard 1 01-24-2008 02:29 PM
