Old 02-24-2016, 05:22 PM
Vaquero Vaquero is offline
Exclamation can't load exported Cal3d Avatars from Autodesk Character Generator
Hello! I'm still trying to get any character to work in vizard besides the ones that are delivered with the software. And it fails! Again.
This time I created an avatar with Autodesk's Character Generator. I followed the steps from the help.
Select the root bone, go to export, select Cal3d Skeleton file, set number of influences to 4 (because I want to use hardware skinning anyway), save.
I changed the materials to contain numbers in square brackets and set to Blinn shading model.
Then I selected the meshes in the file that I want to export (there are several resolutions), export as Cal3d Mesh file. Repeat for meshes of other resolutions.
Exported the 1 material that is used.
Created the cfg correctly.
Trying to open the skeleton file in the Inspector throws this message:
Inspector
Failed to load "F:\\Autodesk.CharacterGenerator\Cal3d\ACG_mSkel.csf":
Warning: Could not find plugin to read objects from file "F:\\Autodesk.CharacterGenerator\Cal3d\ACG_mSkel.csf".
So why is following the vizard instructions failing again?
Old 02-24-2016, 05:34 PM
Of course, trying to open the cfg file in the Inspector throws this message:
Inspector
Failed to load "F:\Autodesk.CharacterGenerator\Cal3d\AUTCC_mSkel_low_Chris_crowd.cfg":
Old 02-24-2016, 05:41 PM
I tried with the standard skeleton, and I used Autodesks script to convert it to Biped, but it just wouldn't work.
Converted to Biped and exported as xsf the skeleton file looks like in the attachment.
Old 02-24-2016, 05:45 PM
NEVERMIND!
I really made a typo in the CFG file, where a comment was missing the leading #!
Problems with avatars facial expressions exported with Cal3D armo Vizard 4 08-28-2014 10:57 AM
Error using CMF export from 3ds max to cal3d in some avatars disbeat Vizard 4 04-15-2014 11:40 PM
Rocketbox -> cal3D exported character turgutm Vizard 5 01-20-2011 10:48 PM
Can I load 7 people avatars with different identities into vizard? Green Vizard 1 10-22-2009 08:37 PM
importing avatars with cal3d marcoleon Vizard 15 04-28-2006 04:48 PM
