Old 06-02-2016, 08:25 AM
JB_HP_Viz JB_HP_Viz is offline
How to set offset for ART SmartTrack
I have the ART SmartTrack working in the Christie HoloStation CAVE but when you put the tracked 3D glasses on it doesn't look like the correct view point for the user. It looks like the users eye point should be set to be higher. So I thought maybe the offset needs to be changed.
Since I was not able to use Vizconnect to setup the tracker is there a way to change the offset like you can in Vizconnect for the tracker (I attached the image that shows how you change settings in Vizconnect, but I didn't see information on how to do if not using Vizconnect to setup Tracker)?
Below I included the CAVE dimensions information. With the Holostation CAVE the floor sits 32 inches off the ground
# Declare constants defining the CAVE dimensions
#height from floor to display 32 inches
#height of display 42.875 inches
W = 1.724       # 67.875 inches wide
H = 1.902       # 74.875 inches tall
#DF = 1.08       # 42.5 inches deep for floor
D = 1.438       # 56.625 inches deep
W2 = W/2.0
C0 = -W2,H,0     # Front  Wall: C1,C2,C5,C6
C1 = -W2,H,D     # Left   Wall: C0,C1,C4,C5
C2 = W2,H,D      # Right  Wall: C2,C3,C6,C7
C3 = W2,H,0      # Bottom  Wall: C5,C6,C4,C7
C4 = -W2,0,0
C5 = -W2,0,D
C6 = W2,0,D
C7 = W2,0,0
#Create front wall
FrontWall = vizcave.Wall(   upperLeft=C1,
                             upperRight=C2,
                             lowerLeft=C5,
                             lowerRight=C6,
                             name='Front Wall' )
#Create left wall
LeftWall  = vizcave.Wall(   upperLeft=C0,
                             upperRight=C1,
                             lowerLeft=C4,
                             lowerRight=C5,
                             name='Left Wall' )
#Create right wall
RightWall = vizcave.Wall(   upperLeft=C2,
                             upperRight=C3,
                             lowerLeft=C6,
                             lowerRight=C7,
                             name='Right Wall' )
#Create bottom wall
BottomWall = vizcave.Wall(  upperLeft=C5,
                             upperRight=C6,
                             lowerLeft=C4,
                             lowerRight=C7,
                             name='Bottom Wall' )
Old 06-05-2016, 11:02 PM
All the wall corners need to be specified in the tracking system's coordinates. In this case you need to account for the image rise off of the floor:
R = 0.81        # 32 inches rise off floor
W2 = W/2.0
C4 = -W2,R,0
C5 = -W2,R,D
C6 = W2,R,D
C7 = W2,R,0
Unless the ART origin is offset from the ground then it should not be necessary to apply a height offset to the tracker. You can add position offsets by creating a tracker link and applying the offset to the link. For example:
# VRPN Tracker connection (to ART Dtrack)
vrpn = viz.add('vrpn7.dle')
headtracker = vrpn.addTracker('DTrack@localhost')           #Default sensor is 0. Head tracker is on DTrack sensor 0
headtracker.swapPos([1,2,-3])
headtracker.swapQuat([-1,-2,3,4])
headTrackerLink = viz.link(headtracker,viz.NullLinkable)
# Adjust for origin offset from ground
headTrackerLink.postTrans([0,1,0])
Offset position of link/attached object MissingAFew Vizard 3 04-13-2015 06:15 PM
Introducing a rotation offset into a link EnvisMJ Vizard 1 11-13-2013 06:51 AM
Textures not loading properly and offset window TarkaDahl Vizard 2 05-18-2010 02:54 PM
window offset on windows 7 IGoudt Vizard 0 02-09-2010 08:06 AM
Offset Problem Elittdogg Vizard 1 09-15-2009 07:28 AM
