Old 07-13-2013, 04:32 PM
brunomartelli brunomartelli is offline
Osg mesh how to add LOD
ive tried this:
http://docs.worldviz.com/vizard/Freq...stions.htm#1_6
to add LOD meshes to my main mesh but doesn't seem to work. Anyone know how to???
thanks
Old 07-19-2013, 08:27 AM
LOd
add the LOD helper, set it to the origion of model, call your LOD meshes LOD01, LOD02 etc. put them into the slots. The max min numbers indicate when the LODs will switch. so first would be say 0 - 500, second 500 - 1000 etc. The number is distance to viewer. empty slots will show up nothing, so you can make the mesh completely disappear
Select all the models and the LOD helper. export osgb, in export options select Export Helpers.
IDK how to change the LOD swap distance in Vizard (i woould love to know)
Old 05-04-2014, 02:34 PM
any ideas about how to set the LOD swap distance?
Old 05-06-2014, 07:11 AM
I'm not sure if this is possible to change from Vizard but I'll look into it and get back to you
Old 05-07-2014, 08:35 AM
The LOD ranges can be edited in Inspector with Vizard 5. Currently, there is no built-in interface for editing them within a script.
Old 05-09-2014, 05:12 AM
Thanks, I'm using a CAVE at Christie Digital in Canada, they have vizard 4. Can I use 5 to edit the LOD then run in the setup they already have?
Old 05-09-2014, 08:17 AM
Yes, you can save out the model after editing the LOD ranges in Vizard 5 Inspector. Then load the model in Vizard 4.
Old 05-12-2014, 07:47 AM
have you a tip for this Jeff? Vizard 4 wont accept it, am i doing something wrong?
Old 05-09-2014, 10:46 AM
thanks Jeff, would you advise me to try Vizard 5 in the CAVE? would that be painful?
Old 05-09-2014, 11:06 AM
..actually the model wont load in Vizard 4 it says"ERROR: 'TerrainTestsSetof8/C1.OSGB' was generated by a newer version of Vizard, and is incompatible with the current version."
Old 05-12-2014, 04:47 PM
masaki masaki is offline
Actually a model modified/saved in Vizard 5 Inspector can not be loaded into Vizard 4. You will have to load it into Vizard 5.
Best,
Masaki
Old 05-14-2014, 08:21 AM
Can I put vizard 5 on my CAVE without breaking anything?
Old 05-14-2014, 10:03 AM
Yes, Vizard 5 will install side by side with Vizard 4 and not break anything.
Mesh Graph (more than vertex position info) jpriede Vizard 0 05-03-2013 07:48 AM
Identify a class via its mesh EnvisMJ Vizard 1 02-15-2012 08:43 AM
Collide mesh on child objects Enlil Vizard 1 08-31-2010 05:52 PM
Multiple Mesh Avatar Texturing v-jbinney Vizard 6 11-13-2007 11:00 AM
changing the texture of an avatars shirt/body bailenson Vizard 19 05-04-2006 10:00 AM
