Old 09-19-2013, 07:18 AM
ChrisMa ChrisMa is offline
Importing Vicon Tracker Data
I found the same issue for Version 3.0. I'm using Vizard 4.0 in the 90days Trial Version.
I want to get the data of segments and markers tracked with Vicon Tracker 2.0 (32Bit). I had some warnings and errors. They were solved by opening the port 800 in the Windows Firewall at the Vizard PC.
If I run the following code, a new window opens, and Shows the World Viz logo on a black Background. The Interactive window stops at loading the Basketball.osgb.
# Add a world
scene = viz.addChild('dojo.osgb')
ball = viz.addChild('basketball.osgb')
ball.setPosition([1,1,1])
vicon = viz.add('vicon.dle',0,'192.168.10.1')
body = vicon.getBody(0)
marker = vicon.getMarker(0)
print body.getName()
print marker.getName()
** Loading Übung_Vizard_1.py
Loading File: dojo.osgb
Loading File: basketball.osgb
On the Nexus PC I allowed Tracker to send and recieve data through the Firewall. In an other post somebody said to allow "kinematic data" as an Output. I don't know where to find that.
Thank you for your help!
ChriMa
Old 09-19-2013, 09:49 AM
The vicon plug-in works with a protocol used by earlier versions of Tracker. You should be able to use vrpn to read body data from tracker in Vizard once you specify the correct VRPN source.
import vizshape
VRPN_SOURCE = 'Tracker0@localhost'
viz.move([0,-1,-5])
axes = vizshape.addAxes(length=0.5)
vrpn = viz.add('vrpn7.dle')
headtracker = vrpn.addTracker(VRPN_SOURCE)
headtracker.swapPos([-1,3,-2])
viz.link(headtracker,axes)
def showData():
	print headtracker.getPosition()
	print headtracker.getEuler()
vizact.ontimer(1,showData)
Old 09-20-2013, 07:27 AM
Hello Jeff,
thank your for your reply. First I used your code with 'Tracker0@192.168.10.1'. I thought Tracer0 referes to Vicon Tracker. Finally I tried to Import one Object I'm tracking with Tracker called Flasche (=bottle) instead of Tracker0. Now it works well.
So I have to Import every object I want to use, separately?
import vizshape
VRPN_SOURCE = 'Flasche@192.168.10.1'
viz.move([0,-1,-5])
flasche = vrpn.addTracker(VRPN_SOURCE)
flasche.swapPos([-1,3,-2])
viz.link(flasche,axes)
def showData():
print flasche.getPosition()
print flasche.getEuler()
Thank you very much!
ChrisMa
Old 09-23-2013, 10:46 AM
Yes, you must connect to each rigid body separately.
Getting positional data from tracker AySz88 Vizard 1 08-03-2011 03:22 PM
About using Vicon Tracker with world viz llqqff Vizard 1 06-28-2010 09:28 AM
vicon pluglin - cluster problems Andy Vizard 2 11-10-2009 01:04 AM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 12:03 AM
Integrating InertiaCube and Vicon data roman_suvorov Vizard 10 05-20-2008 04:30 PM
