Old 02-07-2013, 07:35 AM
Yang Yang is offline
Polhemus Liberty Latus connecting error
I am trying to connect Vizard to Polhemus Liberty Latus.
First of all, I set up the receptor and marker according to the user manual of Polhemus Liberty Latus. Then I launch a wireless marker successfully using the PiMgr program supplied by the Liberty Latus. The marker can track accurately when run with PiMgr.
Then with everything open, I input the following codes in Vizard according to the user reference in Polhemus Plug-in:
polhemus = viz.add('polhemus.dle')
libertylatus = polhemus.addLibertyLatus(marker=0,receptor=1)
It has no problem in creating the Polhemus extension. But trying to connect with Liberty Latus gives me the following error:
** ERROR: Failed to connect to a Patriot Wireless/Libert LATUS: Device not found
** ERROR: Failed to create extension sensor with polhemus.dle
Then I also tried to specify the number for marker and receptor. But same error messages come up.
Thanks in advance. Any help is appreciated.
Old 02-12-2013, 12:57 PM
When you say "with everything open", are you referring to PiMgr? I don't think to applications can access the device simultaneously, so you should close down PiMgr before attempting to connect to the device in Vizard.
Old 02-13-2013, 11:52 AM
Hi farshizzo,
Thanks for your reply. I tried again with PiMgr closed (Liberty Latus & marker open). I got a dialog box jumped out, saying: An unhandled win32 exception occured in winviz.exe[3712].
Any idea why?
Thanks in advance!
Yang
Polhemus Liberty Latus error VIZUNN Vizard 2 02-07-2013 07:13 AM
vrpn error, PPT is connecting sjp Precision Position Tracker (PPT) 1 05-29-2008 09:32 AM
