Old 07-30-2012, 05:59 AM
jaclyn.bill jaclyn.bill is offline
multiple sliders
Hopeing there is a simple answer this this, but how do you distinguish between four sliders so that each slider alters a separate parameter.
I have 4 sliders sliderSWRD, sliderSWEX, sliderRTRD, sliderRTEX set at the four corners of my screen. When I use the follwing code to detect a response from say SWRD and change a parameter it works fine; however, responding with any of the other sliders also changes that parameter and I don't want this to happen.
HTML Code:
def reponse():
	global radadj, radius, adjustswing, swingmiddle
	def myslider(sliderSWRD, pos):
		adjustswing=swingmiddle-pos
		def onMouseDown(button):
			if button == viz.MOUSEBUTTON_RIGHT:
				radius=radius+adjustswing
				sliderSWRD.disable()   ### re-enabled elsewhere
		viz.callback(viz.MOUSEDOWN_EVENT,onMouseDown)
	viz.callback(viz.SLIDER_EVENT,myslider)
Any tips would be useful, sure I'm missing something obvious. Thank you.
Old 07-30-2012, 09:55 PM
You need to check that the slider object passed to the callback function is sliderSWRD before changing that parameter:
def onSlider(obj,pos):
    if obj == sliderSWRD:
        #change parameter
viz.callback(viz.SLIDER_EVENT,onSlider)
You can also use the vizact.onslider command to call different callback functions based on which slider was changed:
def onSliderSWRD(pos):
	#do something
vizact.onslider(sliderSWRD,onSliderSWRD)
def onSliderSWEX(pos):
	#do something
vizact.onslider(sliderSWEX,onSliderSWEX)
Old 08-01-2012, 02:20 AM
Excellent Thank you very much.
Jac
Support for multiple video cards kopper Vizard 2 06-07-2013 04:50 PM
Multiple Cameras for AR artoolkit plugin Pho46 Vizard 3 11-10-2010 07:59 PM
Displaying multiple gui items in one line Enlil Vizard 4 08-05-2009 08:43 AM
multiple shadows using projector theuberk Vizard 13 02-24-2009 03:56 AM
Custom Drop-Down Menus and Sliders south_bank Vizard 2 05-20-2008 05:27 AM
