Old 12-15-2011, 07:55 PM
jacky jacky is offline
mainview of HMD is unfluently
Hi all,
I have a problem that the update speed of HMD mainview is slower than that of my walking or rotating. I even can see the frame of the mainview updates one by one and is unfluent. The script is below:
isense = viz.add('intersense.dle')
tracker = isense.addTracker(port=1,station=1)
viz.link(tracker, viz.Mainview)
Additionally, I find the time of loading the Vizard program, even a simple one, is longer than before. Does somebody know the reasons? Thanks
Old 12-15-2011, 08:37 PM
If you run the following script is the navigation smooth? What is the framerate if you hit F4 while it is running and is it stable?
viz.add('gallery.ive')
Are your results any different when you connect to the Intersense?
Old 12-16-2011, 07:19 AM
Hi Jeff,
When I run the script below
everything is ok. But when I add the codes as below:
viz.go(viz.HMD|viz.stereo)
isense=viz.add('intersense.dle')
tracker= isense.addTracker(port=1,station=1)
viz.link(tracker,viz.Mainview)
the time of loading this program is very long and the mainview of HMD is very unfluent. And I find the usage rate of the CPU is almost 100% when running this Vizard program.
How can I link MainView with HMD and a 3d node? Salvar Vizard 5 03-22-2011 09:14 PM
Link MainView to instable platform sleiN13 Vizard 2 01-10-2011 01:33 AM
Change position of MainView after COLLISION_EVENT kay Vizard 5 10-07-2010 06:06 PM
link MainView moneim230 Vizard 1 09-14-2010 02:47 PM
mainview Moh200jo Vizard 4 02-19-2009 01:32 AM
