Old 11-30-2011, 08:48 AM
sleiN13 sleiN13 is offline
getVisible unexpected behaviour
I wanted to use the visibility of a object to execute (or not) certain code in a vizAction to my surprise all object returned getVisible() is True while I knew that the certain parent object where invisible. A simple test confirmed that child object don't return the correct visibility value
groupA = viz.addGroup()
groupB = viz.addGroup(parent = groupA)
groupA.visible(viz.OFF)
print groupB.getVisible()
>>> True
Is this a bug or by design and in case of the second reason is there a function that will give the result I need?
Old 12-13-2011, 01:17 PM
This is by design. The node.getVisible() command returns the visible flag of the node. It does not take into account the visible flag of any parents.
You can use the node.getParents() command to determine the visibility state taking into account all parent nodes. Example:
group1 = viz.addGroup()
group2 = viz.addGroup(parent=group1)
ball = viz.addChild('beachball.osgb',parent=group2,pos=(0,1.8,2))
label = viz.addText('',parent=viz.ORTHO,fontSize=50,pos=(10,10,0))
def isNodeActuallyVisible(node):
	if not node.getVisible():
		return False
	parents = node.getParents()
	if parents:
		return any(isNodeActuallyVisible(p) for p in parents)
	return True
def UpdateLabel():
	if isNodeActuallyVisible(ball):
		label.message('visible')
		label.message('not visible')
vizact.ontimer(0,UpdateLabel)
vizact.onkeydown('1',group1.visible,viz.TOGGLE)
vizact.onkeydown('2',group2.visible,viz.TOGGLE)
vizact.onkeydown('3',ball.visible,viz.TOGGLE)
Strange Ball Joint behaviour mkmatlock Vizard 1 11-04-2010 05:49 PM
Unexpected carriage return vizmaster Vizard 3 01-23-2007 01:46 PM
Tk with Vizard abnormal behaviour Gilliard Vizard 2 08-04-2005 02:14 AM
