Old 01-13-2011, 05:51 AM
Zword Zword is offline
moving object forward backward
When the mouse is pointed at the object I want to move it depending on wich key i press. A normal int number works but example +=0.5 does not work.
cube = vizshape.addCube()
def moveForward():
	object = viz.pick()
	if object.valid():
		pos += 10
		object.setPosition([pos],0,0)
		print 'move backward'
vizact.onkeydown( 'w', moveForward )
def moveBackward ():
	object = viz.pick()
	if object.valid():
		pos += 10
	print 'move forward'
vizact.onkeydown( 's', moveBackward )
Old 01-13-2011, 12:17 PM
masaki masaki is offline
hello,
the setPosition command accepts lists in [x,y,z] format so try object.setPosition([pos,0,0]). if you're trying to go forward and backward, that's normally along the z-axis so you might want to change it to ([0,0,pos]).
Masaki
Old 01-16-2011, 05:43 AM
That is not working. This is the error I get:
File "C:\Program Files (x86)\WorldViz\Vizard30/python\vizact.py", line 3019, in __onkeydown
self._callGroup(self.__keydownmap[key])
File "C:\Program Files (x86)\WorldViz\Vizard30/python\vizact.py", line 2971, in _callGroup
val = e.call(arg)
File "C:\Program Files (x86)\WorldViz\Vizard30/python\vizact.py", line 2794, in _callStatic
return func(*args,**kwargs)
File "Test wall.py", line 39, in moveForward
pos += 0.5
UnboundLocalError: local variable 'pos' referenced before assignment
My code:
def moveForward():
	object = viz.pick()
	pos += 0.5
	if object.valid():
		viz.callback(viz.COLLIDE_BEGIN_EVENT,oncollide)
Old 01-18-2011, 01:08 PM
You need to assign a value to pos before you add to it:
import vizshape
cube.setPosition([0,1.5,3])
pos = 3
def moveForward():
    global pos
    object = viz.pick()
    if object.valid():
        pos += 0.5
        object.setPosition([0,1.5,pos])
    global pos
    object = viz.pick()
    if object.valid():
        pos -= 0.5
Old 01-20-2011, 09:21 AM
Tnx it worked. Tnx for your time
Attaching sound to a moving object GiudiceLab Vizard 6 08-21-2009 09:52 AM
moving and object by mouse but don't know how to stop the movement nlfrnassimi Vizard 8 04-26-2009 08:23 AM
Moving view with object Xliben Vizard 2 07-25-2005 06:36 PM
