Old 09-11-2010, 04:01 AM
tsgk tsgk is offline
Polygon angles
I was wondering if there is a way of creating on-the-fly polygons with some of the angles greater than 180 degrees. The description of viz.POLYGON is: "Creates a polygon. Each vertex provides a point for the polygon. Each of the inside angles created by linking the vertices must be acute."
Surely there must be a way of creating concave on-the-fly objects!
Thanks in advance,
G
Old 09-16-2010, 03:49 PM
Does using viz.LINE_STRIP work for the shape you want to create?
Old 10-21-2010, 05:06 AM
nige777 nige777 is offline
Hi Jeff,
I too am trying to create concave polygons on-the-fly and am wondering how viz.LINE_STRIP can help me? I see that I can create a concave wireframe shape but am wondering how that can be "filled in" to form a poly??
Old 10-21-2010, 11:59 PM
I could use the line strip, but that left me with only the perimeter of the shape I wanted. Now I am creating the opposite shape of what I want with viz.Polygon and then use the negative space for the shape I want. Also, I have used viz.QUADS to create a shapes which viz.polygon won't let you create because of concave angles.
Hope that helped!
How to add texture to a polygon tsgk Vizard 1 09-17-2010 12:28 PM
PeopleMaker – Polygon Limit SpazViz Vizard 4 06-03-2010 09:17 AM
coalesceing euler angles epl Vizard 6 05-28-2004 05:25 PM
