Old 08-20-2009, 04:38 AM
jaclyn.bill jaclyn.bill is offline
removing clones
Dear users,
I'm running an experiment in which 2/3 trial require poles to be places in the scene, and one trial requires these to be removed.
Early on in my script I use
def addcones():
	global cone
	###########code for placing cones
	for place in (positionlistA,positionlistB,positionlistC,positionlistD,positionlistE):
		pos = (place)
		cone = viz.add('pole.wrl',cache=viz.CACHE_CLONE,pos=pos)
		cone.color(0,1,0)
		cone.setScale(2,0.05,2)
#cones.append(cone)
		if place[3] >0:
			cone.setPosition(1,0,0,viz.REL_LOCAL)
		if place[3] <0:
			cone.setPosition(-1,0,0,viz.REL_LOCAL)
to add the cones and in my trial selection function I use the same code but just remove the cones from the scene.
if trialtype ==0:
			viz.MainScene.visible(viz.OFF,viz.WORLD)
			yield viztask.waitTime(5)
			trial.message('Heading')
			trial.remove()
			createpath()
			cone.remove()
			passiveheading()
			yield viztask.waitTime(0.5)
			viz.MainScene.visible(viz.ON,viz.WORLD)
			yield viztask.waitTime(16.9)
to remove the cones before running the trial. However, it only removes one cone. My understanding is that clones should copy the original? Is this not the case?
I'd appreciate any pointers on this. Many Thanks in advance.
Old 08-20-2009, 04:58 AM
p.s the cone.visible(viz.OFF) command only hides one cone also.
Old 08-20-2009, 10:51 AM
Removing an object will NOT remove clones of it. You will need to call remove() on each individual cloned object, just like any other object.
removing multiple objects durf Vizard 7 08-05-2009 10:15 AM
removing and obj with a timer durf Vizard 0 06-04-2009 08:16 AM
Removing Vertices from an On-The-Fly Object shivanangel Vizard 1 11-05-2008 02:38 PM
executable - removing models Dave Vizard 2 05-13-2008 03:58 AM
