Old 07-10-2009, 05:19 AM
Saz Saz is offline
still problem with data from .exe file
Hi
I'm still having problems with data being output from a .exe file - I read the post as recommended but it was using exactly the same code as I've tried. This is the code I'm using - it works fine in the developmental stage but once the .exe is published, it fails to produce a file.
filename = 'adapt_.txt' + str(subject)
def getPublishedPath(filename):
	#filename = 'adapt_.txt' + str(subject)
	publishPath = viz.getOption('Y:\backup\Vizard30\resources\road\_.txt','')
	if publishPath:
		return '/'.join([publishPath,filename])
	return filename
file = open(getPublishedPath(filename), 'w')
Any ideas?
Old 07-10-2009, 11:12 AM
Have a look at the Publishing as an EXE page in the docs. It shows how to do exactly what you want. Here is some sample code:
f = open( viz.res.getPublishedPath('output.txt') , 'w' )
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
Problem generating exe file Anfo Vizard 1 11-17-2008 05:21 PM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 05:08 PM
