Old 01-07-2008, 01:21 PM
JMOwens JMOwens is offline
Stereo Overlap question
Hi all,
I have a quick question regarding the viz.stereooverlap() function. Can anyone tell me whether this changes the distance between the center of each image or whether it rotates the images to accomplish this varying degree of overlap?
We're trying to set up a new nVis SX111 prototype that has the eyepieces each rotated 13 degrees from parallel around the y-axis, and thought this might do it. Advice is appreciated!
Alternatively, is it possible to address each eye in viz.stereo separately? This way we could just manually rotate each viewpoint by 13 degrees.
Thanks!
Old 01-07-2008, 02:54 PM
We have used this prototype before. You can use the following code to get it working with Vizard:
viz.go(viz.STEREO|viz.HMD)
viz.fov(64.0,1.25)
viz.MainWindow.setViewOffset(viz.Matrix.euler(-13,0,0),eye=viz.LEFT_EYE)
viz.MainWindow.setViewOffset(viz.Matrix.euler(13,0,0),eye=viz.RIGHT_EYE)
Old 01-08-2008, 09:54 AM
Thank you very much!
8800 ultra stereo driver Dave Vizard 21 10-25-2009 11:25 AM
Stereo eye separation ajmurray Vizard 4 10-24-2007 11:56 AM
problem with stereo mode shivanangel Vizard 3 10-17-2006 10:58 AM
quad buffered stereo? halley Vizard 2 10-19-2005 01:28 PM
SeeReal stereo with separate scenes Jerry Vizard 2 10-18-2005 01:02 PM
