Old 06-27-2012, 12:54 PM
Adam.Grey Adam.Grey is offline
does vizard handle input differently when it's embedded?
Is there something special I have to do for vizard embedded to get mouse and keyboard?
I need to embed my vizard window in a WPF control. I adapted this tutorial and this one(thanks farshizzo) to suit and made a nice control that starts up a vizard script and passes the handle to the window I've created as the first paramater. The script, if it sees the first parameter, takes that to be a window handle and embeds itself in that window. It almost entirely works.
However, I can't seem to get input to go through. Microsoft's tutorial works just fine with their own listbox, but I'm not sure if vizard's input is handled differently.
I know the script itself is properly receiving input. If I run this script with the only difference being that it isn't embedded, it responds properly to mouse and keyboard input.
I know vizard isn't hanging or blocked out of input: The ball spins, and if I check the keyboard state manually (e.g., viz.key.isDown(' ', True)), I can see if keys are up or down. onkeydown doesn't seem to work, however.
p/invoking win32's setfocus does not appear to do anything.
here's the vizard script:
viz.add('tut_ground.wrl')
ball = viz.add('ball.wrl',pos=(0,1.8,2))
ball.add(vizact.spin(0,1,0,90))
def mytimer(num):
	if num is 0:
		ball.setPosition(0, 1.8, 4)
	elif num is 1:
		if viz.key.isDown(' ', True):
			ball.setPosition(0, 1.8, 3)
vizact.ontimer(0.1666, mytimer, 1)
vizact.ontimer(1.5, mytimer, 0)
vizact.onkeydown('b', ball.setPosition, [0,1.8,5])
if(len(sys.argv) > 1):
	viz.go(viz.EMBEDDED, window=int(sys.argv[1]))
	while True:
		viz.updateframe()
and here's the vizard box control:
using System;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Input;
using System.Windows.Interop;
using System.Runtime.InteropServices;
using System.Diagnostics;
namespace vizardbox
    public partial class VizardBox : UserControl
        public String VizardAdditionalStartupArguments
            get { return (String)GetValue(VizardAdditionalStartupArgumentsProperty); }
            set { SetValue(VizardAdditionalStartupArgumentsProperty, value); }
        public bool VizardConsole
            get { return (bool)GetValue(VizardConsoleProperty); }
            set { SetValue(VizardConsoleProperty, value); }
        public String VizardScript
            get { return (String)GetValue(VizardScriptProperty); }
            set { SetValue(VizardScriptProperty, value); }
        public String VizardInstallation
            get { return (String)GetValue(VizardInstallationProperty); }
            set { SetValue(VizardInstallationProperty, value); }
        public static readonly DependencyProperty VizardAdditionalStartupArgumentsProperty = DependencyProperty.Register("VizardAdditionalStartupArguments", typeof(String), typeof(VizardBox), new UIPropertyMetadata(""));
        public static readonly DependencyProperty VizardConsoleProperty = DependencyProperty.Register("VizardConsole", typeof(bool), typeof(VizardBox), new UIPropertyMetadata(false));
        public static readonly DependencyProperty VizardScriptProperty = DependencyProperty.Register("VizardScript", typeof(String), typeof(VizardBox), new UIPropertyMetadata(""));
        public static readonly DependencyProperty VizardInstallationProperty = DependencyProperty.Register("VizardInstallation", typeof(String), typeof(VizardBox), new UIPropertyMetadata("C:\\Program Files (x86)\\WorldViz\\Vizard4\\bin\\winviz.exe"));
        vizHwndHost vh;
        public VizardBox()
            InitializeComponent();
        public void Go()
            vh = new vizHwndHost();
            _hostborder.Child=vh;
            vh.go(VizardScript, VizardInstallation, VizardAdditionalStartupArguments, VizardConsole);
        public void Stop()
            _hostborder.Child = null;
            vh.stop();
    public class vizHwndHost : HwndHost
        IntPtr hwndVizardHandle;
        Process vizardProc;
        ~vizHwndHost()
            stop();
            DestroyWindow(hwndVizardHandle);
        public void stop()
            if (vizardProc != null)
                if(!vizardProc.HasExited)
                    vizardProc.Kill();
        public void go(string script, string vizardLocation, string additionalStartupArguments, bool console)
            vizardProc = new Process();
            vizardProc.StartInfo.FileName = vizardLocation;
            vizardProc.StartInfo.Arguments = (console? "-console" : "") + " \"" + script + "\" " + hwndVizardHandle.ToString() + " " + additionalStartupArguments;
            vizardProc.Start();
        protected override HandleRef BuildWindowCore(HandleRef hwndParent)
            hwndVizardHandle = IntPtr.Zero;
            hwndVizardHandle = CreateWindowEx(0, "static", "",
                                      WS_CHILD | WS_VISIBLE,
                                      0, 0,
                                      0, 0,
                                      hwndParent.Handle,
                                      (IntPtr)HOST_ID,
                                      IntPtr.Zero,
                                      0);
            return new HandleRef(this, hwndVizardHandle);
        protected override IntPtr WndProc(IntPtr hwnd, int msg, IntPtr wParam, IntPtr lParam, ref bool handled)
            handled = false;
            return IntPtr.Zero;
        public void setFocus()
            SetFocus(hwndVizardHandle);
        protected override void OnGotMouseCapture(MouseEventArgs e)
            base.OnGotMouseCapture(e);
            e.Handled = true;
        protected override void DestroyWindowCore(HandleRef hwnd)
            DestroyWindow(hwnd.Handle);
        //PInvoke declarations
        [DllImport("user32.dll", EntryPoint = "CreateWindowEx", CharSet = CharSet.Unicode)]
        internal static extern IntPtr CreateWindowEx(int dwExStyle,
                                                      string lpszClassName,
                                                      string lpszWindowName,
                                                      int style,
                                                      int x, int y,
                                                      int width, int height,
                                                      IntPtr hwndParent,
                                                      IntPtr hMenu,
                                                      IntPtr hInst,
                                                      [MarshalAs(UnmanagedType.AsAny)] object pvParam);
        [DllImport("user32.dll", EntryPoint = "DestroyWindow", CharSet = CharSet.Unicode)]
        internal static extern bool DestroyWindow(IntPtr hwnd);
        [DllImport("user32.dll", SetLastError = true)]
        static extern IntPtr SetParent(IntPtr hWndChild, IntPtr hWndNewParent);
        [DllImport("user32.dll")]
        static extern IntPtr SetFocus(IntPtr hWnd);
        internal const int
          WS_CHILD =       0x40000000,
          WS_VISIBLE =     0x10000000,
          LBS_NOTIFY =     0x00000001,
          HOST_ID =        0x00000002;
<viz>.go, csharp, embed, win32, wpf
recording screen in vizard when embedded in wxpython Renato Lima Vizard 0 11-21-2011 02:10 PM
embedded Vizard tavaksai Vizard 5 12-21-2004 08:49 AM
