Old 01-24-2012, 02:01 PM
Kaminski Kaminski is offline
Y Position different than 3.0
Hi All,
Did anybody experience any differences in Y positioning when going from Vizard 3.0 to 4.0?
We are using an intersense I-900, and although the position outputs the same, the viewpoint seems to be a couple of meters lower in the few scripts I have tested so far. I have tried experimenting with the eyeheight but it doesn't seem to change anything. It only happens when tracking is enabled. Anybody have this issue?
Old 01-24-2012, 02:09 PM
Are you linking the sensor to the viewpoint? In 3.0, the eyeheight would be added to the Y value of the link source, unless the viz.LINK_POS_RAW flag was used. In Vizard 4.0, this is not the case and the eyeheight is ignored when linking.
Old 01-25-2012, 08:10 AM
I was linking and that seems to be the issue. Would the best way to modify old scripts be a postTrans on the link position, adding default eyeheight to the Y position?
Old 01-25-2012, 11:26 AM
Yes, you can use either the postTrans or setOffset commands to add an offset to the Y position.
joystick position nmohandes Vizard 2 01-16-2012 10:03 AM
Dynamic Position and Radius of Sphere hotshotiguana Vizard 1 03-23-2011 12:53 PM
Translate view from sensor position to lens position? Kaminski Vizard 4 03-09-2011 10:36 AM
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 08:15 PM
