Old 02-12-2008, 01:29 PM
RedSpikeyThing RedSpikeyThing is offline
Multiple Copies of same sensor plugin
I'm trying to write a sensor for Vizard that simply regurgitates a text file of (x, y, z) positions whenever the update function is called. Internally, it uses a vector to keep track of which sensor is associated with which file. This works as expected with one sensor.
When a second sensor is added, however, no data is returned and Vizard simply gets (0, 0, 0). I've tried outputting the memory address of the sensor that is passed as a parameter to the DLS and it is always the same. This suggests that either Vizard is never calling the update function with the second sensor, or that it is calling it with a pointer to the same sensor. I should note that each sensor does call the initialize function properly and that two separate memory addresses are received when they are initialized.
Any help would be greatly appreciated. Thanks!
Old 02-12-2008, 03:06 PM
The UpdateSensor function is called once per frame, regardless of how many instances of your sensors have been created. You should store each sensor pointer in a global vector during initialization, then iterate through them in the UpdateSensor function. Here is some pseudo code that should explain the general idea:
typedef struct {
	VRUTSensorObj*		instance;
	SOME_OBJECT_HANDLE	handle;
} MySensor;
std::vector< MySensor > m_sensors;
void InitializeSensor(void *sensor)
	//Create internal sensor object
	MySensor ms;
	ms.instance = (VRUTSensorObj *)sensor);
	ms.handle = CREATE_OBJECT_HANDLE;
	//Save sensor number in user field
	ms.instance->user[0] = m_sensors.size();
	//Set data size
	ms.instance->dataSize = 7;
	//Notify successfull initialization
	ms.instance->status = TRUE;
	//Save object in global array
	m_sensors.push_back(ms);
void UpdateSensor(void *sensor)
	//Update 'data' field of all sensors
	for(unsigned int i = 0; i < m_sensors.size(); ++i) {
		GET_OBJECT_DATA(m_sensors[i].handle,m_sensors[i].instance->data);
Let me know if anything is unclear.
Old 02-12-2008, 03:10 PM
beautiful, thank you for the quick reply. The lack of documentation for this is very frustrating...
multiple shadows using projector theuberk Vizard 13 02-24-2009 03:56 AM
Multiple Mesh Avatar Texturing v-jbinney Vizard 6 11-13-2007 12:00 PM
Multiple labs Plymouth Vizard 1 03-05-2007 10:43 AM
Multiple Stages in one Program Amit Vizard 7 11-11-2005 11:20 AM
Multiple Environments bstankie Vizard 1 11-17-2003 11:49 AM
