Old 09-21-2022, 01:19 PM
apenngrace apenngrace is offline
Cluster Master Load Options
Are there any command line options around the cluster master application?
We use Vizard in our CAVE, and the machine that runs the cluster master has multiple network interfaces. By default, Cluster Master has the boxes checked for all the network interfaces. Every time we restart the system, we manually uncheck one of those.
I tried launching from the command line with arguments like VizClusterMaster.exe --help, but nothing is output - it just launches the GUI application.
Old 02-03-2023, 04:18 PM
sado_rabaudi sado_rabaudi is offline
There are some global settings for the cluster tool, but these are read only.
https://docs.worldviz.com/vizard/lat...hlight=options
The Cluster Tool by default should save what you have selected however. Are you able to select other options in the Cluster Tool and have them save (such as "Show Others")?
Best,
Sado
"Launching in cluster master mode." when cluster mode disabled jpriede Vizard 2 02-12-2013 03:33 PM
No rendering on Cluster Master victorqx Vizard 1 06-04-2012 09:42 AM
Automatically set Cluster Master Settings pcatalano Vizard 2 01-28-2011 02:09 PM
Cluster Help videcuk Vizard 12 09-21-2007 03:14 PM
