Old 02-15-2021, 10:01 AM
hguo hguo is offline
Registered User
VIVE Pro Eye (with SteamVR) Display issue
I am using a VIVE Pro Eye with SteamVR and SRanipalRuntime, and I am trying to run scripts on Vizard 7 Enterprise.
Anything from Vizard displays nothing (black screen) on my HMD display. I could still see the grid on the edge of my play area, but I can see nothing from Vizard.
I can see the connection is established as the winviz application started running on SteamVR. Also, the window on my monitor was showing the view with position of the HMD tracked. The controllers could be tracked as well. The only problem is with the HMD display.
I tried both examples: viveProEyeExample.py and steamvr.py, and also vizconnect. All of them give me the same thing.
I have no problem running SteamVR home, or other SteamVR game applications.
Tried restarting applications/machine, re-installing Vizard, and SteamVR, did not work.
Please help. Thanks!
Old 08-25-2021, 09:53 AM
What graphics card are you currently using? And is your version of Vizard up to date? I've seen that issue sometimes when there is another version of winviz.exe running in the background, but restarting the computer should fix that issue. One other thing to check is your SRAnipal up to date? It may be prompting you to update SRAnipal in the background?
Best,
Sado
display, htc vive, steamvr, vive
steamvr controller for htc vive unresponsive zumbay Vizard 2 05-25-2018 11:02 PM
Check for running SteamVR A Wundlechner Vizard 2 01-11-2018 01:03 AM
Vizconnect Display Issue ghostx Vizard 3 07-31-2016 07:46 PM
Duplicate HMD display on primary monitor, with eyetracking info performlabrit Vizard 3 09-19-2014 10:44 AM
