Old 04-30-2020, 05:18 AM
Daryan Daryan is offline
Disable Normal Mapping
I am looking for a way to disable normal mapping. I don't want to remove the normal maps, because I need to enable normal mapping again, later in the code.
Thanks!
Daryan
Old 06-12-2020, 01:51 PM
vizstan vizstan is offline
Hi Daryan,
I apologize for the delayed response. If you are under our Vizard support contract, I would highly recommend you to send questions to support@worldviz.com to get our timely response within 24hrs. In the meantime, if you can provide me with the name of your institute or the registered account name, I would be happy to assist you from there. I will check with our Vizard exporters regarding your question.
Best,
Stanley
depth map, disable, height map, normal map
Normal map problem tokola Vizard 5 02-15-2013 09:51 AM
Normal Map Light Wehrdo Vizard 1 07-06-2011 06:45 AM
Normal Map Workflow for Vizard shivanangel Vizard 2 03-10-2009 06:54 PM
mapping method FlyingFish Vizard 1 07-12-2007 09:06 AM
